| Home > Technical Chat > Gear box ratios ????????? | |||||||
31st Jan, 2008 at 07:38:04pm
Right, Am after buying a dog box for the min, got one located secondhand but want to make sure it will suit my needs.
Edited by cossierick on 31st Jan, 2008. |
31st Jan, 2008 at 07:40:22pm
what ratios?
31st Jan, 2008 at 07:46:58pm
Sorry thats the bit i forgot. lol |
31st Jan, 2008 at 07:57:15pm
On 31st Jan, 2008 cossierick said:
Lay gear 16T 22T 24T 26T Other Shaft 27T 24T 21T 19T (Flywheel end of gear box) If you mean (starting from the centre web, working outwards) Laygear 16T 22T 24T 26T MainShaft 27T 24T 21T 19T then: 1st: 2.28 2nd: 1.48 3rd: 1.19 4th 1.0 Edited by turbodave16v on 31st Jan, 2008. On 17th Nov, 2014 Tom Fenton said:
31st Jan, 2008 at 08:00:05pm
Sorry am not that clever doesnt mean anything to me,
![]() 6753 Posts Member #: 828 Post Whore uranus |
31st Jan, 2008 at 08:01:58pm
thats a really high 1st gear , be a bit of a job in traffic with a 3.2 and higher diff Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
31st Jan, 2008 at 08:02:32pm
31st Jan, 2008 at 08:03:39pm
Prob looking at running a 3.9 with a sailsbury lsd
31st Jan, 2008 at 08:03:49pm
They are not normally what one would use for a turbo to be honest; they are pretty close.
31st Jan, 2008 at 08:08:34pm
those ratiod are very similar to the set in the Don, using a 3.9 FD,
31st Jan, 2008 at 08:11:37pm
ok, I'll pass the ball over to you.
31st Jan, 2008 at 08:15:10pm
Carl is a guy from mini7 that moving from sevens to migs
31st Jan, 2008 at 08:19:35pm
Dave thats brilliant thanks, wot sort of top speed can i be looking at then ? planning on 7k limit.
31st Jan, 2008 at 08:22:09pm
yep i agree dave , my 2.59 and 3.1 diff=8.03 is a bit higher than id like on hills . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
31st Jan, 2008 at 08:24:40pm
@ Robert - -that's what i'm also using and it sucks on inclines. Guess we need to join weight watchers.
31st Jan, 2008 at 08:47:18pm
2.14x3.9=8.346, so easir on the car than you boys to get moving,lol |
31st Jan, 2008 at 08:59:56pm
well i m down to 660kg and on the high st hill in burford , im at 3 psi just pulling away from a parking space up the main street , turns heads a bit !!! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
31st Jan, 2008 at 11:22:31pm
Would it be better to change the fd to a higher one or is the real solution to have the gears further apart ?
31st Jan, 2008 at 11:28:42pm
rick , dont worry too much about the ratios,
31st Jan, 2008 at 11:31:16pm
Am sure you carnt get much lower than that fd for a lsd tho can yo carl (or can you machine a std one ) |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
1st Feb, 2008 at 12:25:00am
I had a synchro version of the dog box ratios. (Challenge set) and first was waaaaay to high. Brilliant for rolling starts or a silly race engine. It was useless though. See if you can plot the cascade curves for your engine and see where the best places for the gears are. I now have a 2.54 set again, which are probably a bit close for a half decent FD which the engine could pull. Bugger off, I'm getting there. |
1st Feb, 2008 at 10:06:15pm
Thanks for all the help and advice, its realy given me a lot to thing about (maybe too much )
1st Feb, 2008 at 11:45:53pm
rick, you can get 3.54 , 3.6. 3.7 fd's in lsd pattern |
2nd Feb, 2008 at 12:25:53am
and 3.4s "Turbo's make torque, and torque makes fun"
2nd Feb, 2008 at 09:20:26am
On 2nd Feb, 2008 joeybaby83 said:
and 3.4s thats what i meant,lol, not 3.54. |
