Home > Help Needed / General Tech Chat > New Head
Simon
Member #: 1865
Norwich, Norfolk
I picked up a cheap 1275 head on ebay for £85, it needs an acid dip and new valves, springs, guides etc but im trying to find out what stage it is at the mo.
It is a 12G940 head with "OE 55-20-0" stamped on it.
A bit of research show it has been worked on by Oselli and they say this will have a 20cc chamber with 1.312 inlet and 1.156 exhaust valve. It is a 9 stud head and just one level up from standard.
Any comments on the head? and what is "one level up" ?
Let's just say it's useless for a forced induction application because of the small chambers.
One level up means nothing.
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
depend, combined with 15 or 18cc pistons,will make a very good set up, oselli st1 head seem to be road set up with mild cam and mid rev efficiency, that's exactly what's a turbo engine is
Get captain Benross to Open the Chambers up!
Simon
Member #: 1865
Norwich, Norfolk
im getting it acid dipped this weekend and to get the ports and valves measured as I have a feeling there might be some post oselli work on it.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
It's been skimed to reduce chamber size, and as Vegard says you potentially want to do the opposite (depending on boost, pistons, engine spec etc).
On 7th Nov, 2008 Nic said:
naeJ
m
