| Home > Beginners Tech > Turbo'ing my 1300? help please | |||||||
1 Posts Member #: 2241 Junior Member |
1st Feb, 2008 at 08:49:33pm
basically i want all replies explained as if i was a spaz (got some basic mechanical skills but just for this sake, think i havent).
77 Posts Member #: 2204 Advanced Member Hertfordshire |
1st Feb, 2008 at 09:11:21pm
Hi mate
1st Feb, 2008 at 09:22:45pm
On 1st Feb, 2008 HeavyMetalp11 said:
Ive got hold of a turbo from a mates volvo. abit small but thinking it will give good quick spool up. I would have thought that the volvo's turbo would be too big, what turbo is it and what is the AR? On 1st Feb, 2008 HeavyMetalp11 said:
1) i have acquired a 45 dcoe weber carb, can i use this if i choose to turbo? Only if you go for a suck through set up. For a blow through set up you'll need a sealed carb, most people here use the HIFF 44 off the Metty Turbo as it works well and there's no point in reinventing the wheel. The general view in the turbo world is that suck through set-ups suck, although they seem quite common on supercharged engines. On 1st Feb, 2008 HeavyMetalp11 said:
2)dump valve, yes / no? recirculating/ vent to atmosphere? Not strictly needed but they will help you're turbo last longer. Recirculating are quieter, but vent to are are simpler to install. On 1st Feb, 2008 HeavyMetalp11 said:
3) can you run without an intercooler? Yes, there are lots of production cars without ICs for example the Metro Turbo. However as one great turbo tuner once said: "An intercooler is not the icing on the cake, it is more cake" On 1st Feb, 2008 HeavyMetalp11 said:
4) if no to the last question, how big should one be and whats the best way of mounting? How much space have you got in your engine bay? On 1st Feb, 2008 HeavyMetalp11 said:
Im sorry if im asking questions a million others have done already. any info would be greatly appreciated Been asked many times before, a quick search and a bit of background reading will really help. Isambard Kingdom Brunel said:
1st Feb, 2008 at 09:27:33pm
Here is a fantastic guide:
1st Feb, 2008 at 09:53:27pm
And here's how to do it in 20 hours
Edited by wil_h on 1st Feb, 2008. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
1st Feb, 2008 at 10:02:13pm
On 1st Feb, 2008 wil_h said:
And here's how to do it in 20 hours You forgot the link! http://www.twin-turbo.co.uk/Wil/HOW_I_CONV...IN_20_HOURS.pdf Isambard Kingdom Brunel said:
11th Feb, 2008 at 06:48:53pm
What you need if you can get hold of one is a Metro Turbo car complete.
Edited by Mr Joshua on 11th Feb, 2008. Own the day
11th Feb, 2008 at 08:13:50pm
On 11th Feb, 2008 Mr Joshua said:
There is no need to rush and I would caution that from start to finish will take a damned sight longer than 20hrs. Without the bulkhead modification it would mean sourcing some very specfic items or having them made. Well It too me 20 hours from start to finish of fitting everything, but gathering all the parts too a couple of months. The only specialist parts were the actuator bracket and breather, everything else was off the shelf bought and not in the slightest difficult to source. The point of the exercise, to be honest, was to show that turboing a mini is not difficult and can be done in a very short time. Also, that turboing a 70,000 mile engine (with a bit of thought) can be done and it won't suddenly blow up (3000 miles and counting). On 11th Feb, 2008 Mr Joshua said:
For those who say that the orginal Mini tank fuel outlet is sufficent to supply the standard Metro Turbo fuel pump you are in error! If your cars are running 100 plus brake then you are lucky your pump has not cavitated and stalled the fuel flow. Interesting, I've never had a problem, anyone else? As the pump runs at a constant rate, with the unused fuel returning to the tank it would cavitate from start no mater how many bananas you had, but my pre-filter is always full. Sure it's a restriction and not ideal, but seem ok in my car. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
11th Feb, 2008 at 08:37:52pm
Ive never had a problem, but if you don't remove the scummy filter inside the tank then you may get a problem with cavitations/blockages! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
11th Feb, 2008 at 08:40:55pm
And mine.
In the 13's at last!.. Just |
13th Feb, 2008 at 07:57:37pm
Then you are all very lucky! Took me an age to figure out what was going wrong. which got me looking into all the Rover cars that used this type of fuel pump.
Edited by Mr Joshua on 13th Feb, 2008. Own the day
13th Feb, 2008 at 08:24:43pm
here is a link to another thread for you. all your questions should be answered within http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6
