| Home > Wanted > Rocker Assembly for Small Bore Engine | |||||||
152 Posts Member #: 2190 Advanced Member South Carolina, USA |
1st Feb, 2008 at 11:37:20pm
For some reason the mini I purchased had the rocker assembly removed from the 1098 engine. Does any one a good small bore rocker assembly they would like to sell me cheap? For now, I would like to get the engine running with the stock rockers and upgrade later on….I have already spent too much on the bottom end |
1st Feb, 2008 at 11:41:24pm
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=201184 On 13th Jul, 2012 Ben H said:
1st Feb, 2008 at 11:51:36pm
I did see those....I was hoping for something a bit cheaper...It will probably cost ~$30-40 to ship to the states and he has these starting at ~$80.
2nd Feb, 2008 at 08:26:37am
I've got plenty of 998 sets in useable you can have for the cost of shipping.
2nd Feb, 2008 at 02:54:26pm
That would be awesome! |
![]() 9326 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
2nd Feb, 2008 at 06:52:39pm
Is there a difference between std rockers on a 998 and 1275? Edited by Nic on 2nd Feb, 2008. |
2nd Feb, 2008 at 07:13:22pm
The spacing is different, as the 12G940 valves are further apart. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2nd Feb, 2008 at 08:05:38pm
If you look at the pad on the pressed rockers, the 998 ones are round whereas the 1275 ones are oval, and are supposedly higher lift. Edited by Vegard on 3rd Feb, 2008. On 13th Jul, 2012 Ben H said:
2nd Feb, 2008 at 08:50:53pm
pas? |
2nd Feb, 2008 at 09:03:35pm
As you are in America check out the British car part guys, 998 1098 and 1275 A series engines were in Sprite/Midgets and You'll find em at British speciality scrapyards, probably locally. if not try my mate at
…I figure the rockers would be easy to change in the future.
