Home > General Chat > rollcage spreader plates
martpaul
Member #: 668
newton aycliffe (near durham)
hi all,
does anyone know what the dimensions of the plates welded into the body for a rollcage? well mainly the width and thickness.
just my rollcage wont be delivered for 6 to 8 weeks from the roll centre, but i was hoping to get my shell finished before then,
so was thinking of welding in a plate from the cross member to bulkhead and b pillar to the back. if you understand what i mean? then just drill the holes when the rollcage arrives.
Would this be ok do you think?
thanks martin
fook me thats a bit overkill and heavy!
your roll centre cage may come with plates, but there are 120sqmm and 3mm thick. (now you can see why it would be heavy!)
you can always just dust over with the paint afterwards. i cant see it doing any harm.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I could go and find the plate dimensions (do a search it has been asked recently), but how are you going to get the plates in the correct position before getting the cage. I would be cautious about welding the plates in without the cage to double check the position is correct.
http://www.twin-turbo.co.uk
martpaul
Member #: 668
yeah i thought it was a wild shot lol,
i just thought while i was on welding at the mo.
thanks tho, ill just finish the shell but leave that area in primer,
thanks martin
don't put waxoil, underseal on the outside of the sills either. dont want a fire *smiley*
martpaul
Member #: 668
lol nope
i post about this before its in the search engine :), http://turbominis.co.uk/forums/index.php?p=vt&tid=195703
thickness is 3mm iirc
Edited by Paul R on 2nd Feb, 2008.
