Home > Help Needed / General Tech Chat > fuel pump
matt101
Member #: 1457
Quick question, is it possible to have a fuel pump which is too big? Currently using a facet square type pump but am finding it not "man" enough. I have a bmw pump but am wondering whether this would be too big/ powerfull? Cheers
if you're using a facet pump for a turbo then it will not work.
Ideally you want a metro one with a metro regulator as they are matched. some people have found using other pumps has stretched the diapraghm in the reg.
they need to be a high pressure, roller van injection style pump for a turbo as it needs to supply 4psi + boost.
*smiley*
