| Home > Help Needed / General Tech Chat > drop gears, i'm confussed | |||||||
282 Posts Member #: 1404 Senior Member The Netherlands |
3rd Feb, 2008 at 06:13:12pm
there is nothing wrong with a A-series that a turbo can't fix.
3rd Feb, 2008 at 06:17:53pm
can you not get a 23t input to match the primary and maintain a ratio of 1:1? "Turbo's make torque, and torque makes fun"
3rd Feb, 2008 at 06:21:29pm
the last part comes with the bushes already fitted so they should not need reaming.
4th Feb, 2008 at 11:24:35am
I must looked over the 23 t input because now i found it there is nothing wrong with a A-series that a turbo can't fix.
4th Feb, 2008 at 11:38:31am
paneermeel, order the minispares 24t drop gear set, TIMKING idler
4th Feb, 2008 at 11:57:13am
the primary may need reaming. This depends on the dimensions of the crank. I have talked with Rich at msn about this before he had the accident. He told me it would always need to be checked! |
4th Feb, 2008 at 03:23:59pm
23t will be louder on the road.
4th Feb, 2008 at 10:41:45pm
there not
5th Feb, 2008 at 12:30:52am
wish I had known that when I bought mine, lol
![]() 695 Posts Member #: 984 Post Whore Westhoughton, Bolton |
5th Feb, 2008 at 08:03:51am
On 5th Feb, 2008 Sprocket said:
wish I had known that when I bought mine, lol so loud people in the street turn to look, probibly thinking there's summit wrong with that
I like it though Mine are quieter
5th Feb, 2008 at 11:23:16am
On 4th Feb, 2008 BENROSS said:
there not hahaha,
the answer i was thinking about
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
5th Feb, 2008 at 11:23:50am
Wished i knew that also before i brought my 23t drop gear set.
Shit Happen's |
5th Feb, 2008 at 11:41:01am
http://minispares.com/Product.aspx?pid=34676
-MINI CLUBMAN 1380 TURBO- |
5th Feb, 2008 at 01:08:48pm
that was one of my first questions there is nothing wrong with a A-series that a turbo can't fix.
5th Feb, 2008 at 01:51:08pm
if you get the gear set as mentioned with the timkin idler
5th Feb, 2008 at 01:53:15pm
I dare to correct you benross. it depends on the crank, and the clearance between the bushes in the primary should be checked. They are often right, but not always... |
5th Feb, 2008 at 09:04:49pm
never had any issues and i have fitted dozens, does not mean that there isnt any..................... something maybe to watch out for
5th Feb, 2008 at 09:13:10pm
better to check one's than destroy a engine there is nothing wrong with a A-series that a turbo can't fix.
6th Feb, 2008 at 12:05:47am
whats are you trying to say? that some cranks diameters can vary? or that the crank wears in this area?
6th Feb, 2008 at 01:27:21am
6th Feb, 2008 at 07:19:08am
I have had one seize on the crank so thats why I talked with Rich about it. Also, about wear on the crank in this location. Ask Sprocket about that. He recently sold a crank with wear on this location (buyer knew). I have seen this before too. So it does happen, and will need to be checked.
