Home > Introduce Yourself > burning oil
kerwin12
Member #: 2244
mulbarton, norwich nr14 8gs
hello all, i have a small problem with burning oil, when you start the car it smokes badly and when its warm it leave smoke clouds when you put your foot down a bit. it is not the turbo as i have cheacked the spark plugs and found that oil is all over piston no 3, the rest are fine. has anyone one had this kind of problem and how much do you think it would cost to sort out?
cheers
valve guides/stem seals,on that piston
id say.
Second that.
please do a compression test
this will eliminate the rings .. piston problems
my moneys on the rings
