Home > Help Needed / General Tech Chat > Burning oil
kerwin12
Member #: 2244
mulbarton, norwich nr14 8gs
hello all, i have a small problem with burning oil, when you start the car it smokes badly and when its warm it leave smoke clouds when you put your foot down a bit. it is not the turbo as i have cheacked the spark plugs and found that oil is all over piston no 3, the rest are fine. has anyone one had this kind of problem and how much do you think it would cost to sort out?
cheers
slater
Member #: 1291
Suffolk / Birmingham
Sounds like your rings on no.3 are shot.
Full rebuild time. (cost depends on how muh you do yourself and what else you find wrong with it)
valve guides stem seals on no 3
slater
Member #: 1291
aye now i read the 'put your foot down' bit it does sound more like guides.
kerwin12
Member #: 2244
ok, what sort of price range would i be looking at to get a new set of valve stem seals fitted? i have only just got the mini and i am low on cash at the mo as i went all out to get the thing. oh and chears for your help peps
slater
Member #: 1291
guides are easy but you will also have to get the seats cut which will put the cost up.
Phone you local engineering shop and ask :)
antman
Member #: 358
Snetterton, Norfolk
For head work and stuff around your way try TMW engineering out at Stalham. Very good machine shop and mini friendly.
do a compression check to eliminate the bores
my bet is on the the piston rings
