Home > For Sale > 2wd cooler and front rad
Cossie 2wd IC, Excellent condition. £30 posted
Meastro rad, its brand new I was going to use it with an IC beside it but changed my plans so no longer needed. £30 posted
MiniKid..
Member #: 1744
Kent & London
1st dibs on rad.... ill take it but could i see a pic 1st... not back on the comp till friday but ill paypal the money thenn
Matty, can I have the IC.
I've got a new alloy one, but fitting it has proved to be a bastard!
PM me you Paypal email.
Carl
Member #: 95
liverpool-on-sea
was thinking the other day if you got a pulley machined with the misssing tooth in a different place then you could have your sensor in a different place if its in the way now.
just a thought
There is a pic up on the first post, or is it not showing on your computer?
PM sent
just a thought
I was thinking along the same lines. I though that you could set the sensor position on the MJ though?
No you cant unfortunately, however
What you could do it move it say 45deg and then + or - 45 from each value depending on where you put it
Carl
Member #: 95
liverpool-on-sea
thought you could have the missing tooth wear ever you wanted so long as the sensor was 90 degrees before it, oh well sorry new inter cooler will be easier and cheaper and may even be better than the one you bought.
Gary, IC sent today, will be with you tomorrow. *wink*
Cheers Matty,
Carl, I think your solution would work. I would have to have a new pulley machined.
MiniKid..
Member #: 1744
Kent & London
Can see it now...
Paypal?
or file another keyway in your existing pulley*wink*
On 8th Feb, 2008 theoneeyedlizard said:
Cheers Matty,
On 8th Feb, 2008 MiniKid.. said:
Can see it now...
Paypal?
Pm sent.
Do what? What would I do with the existing keyway? Chemical metal?
Cheers Matty,
just leave it,
I can't remember whose but someone sells a cam drive setup where you adjust the timng by using diferent keways, it had about 9 keways cut into the crank gear.
Not a bad idea that Joe!
And thanks for the cooler Matt. Arrive yesterday.
