Home > MS Trials & Testing > MS hardware configuration
On 4th Jul, 2008 Paul S said:
I've just put the resistor and LED between VCC and the C12 pin hole.
It flashes at half the frequency of the ignition output LEDs so the signal is clean and consistant at engine speeds.
Excellent,
I obviously took too long writing my thoughts so things appear in the wrong order !!!
Hmmmm, when I said "where is the code?" I meant where does the siamese code come from to get to my laptop to load to the CPU.
I've downloaded both the normal MS2 code (currently in my MS to test it) and the Extra code - just on my laptop so far, wasn't going to load that to the CPU until I've finished my last bits of "Extra" circuitry - but is there another part of the MSEFI site that the siamese code gets downloaded from, or is it from Jean direct, or is it hidden away in the "Extra" code and i've not spotted it yet ????
I got it from Jean direct. You also need a copy of the Megatune ini file so that they talk the same language.
I can email you a copy. I think I have your email address.
Yes please.
I won't be doing anything physical for the next couple of weeks but it would be nice to check it loads OK.
