Home > Help Needed / General Tech Chat > Could it be the clutch ?
Markie_D
Member #: 1660
Formally Mini_Uk
London
Right then,
Put the car on the ground today after months of building etc.
when i started her, i could hear something dragging. *surprised*
So when i pushed the clutch down it stops.*tongue*
could it be the clutch dragging ? It has a new verto clutch, clutch plate, thrus bearing, new clutch master cylinder, slave cylinder, etc.
I get all gears fine.
Some help would be very gratful...
Cheers *smiley*
Shit Happen's
drop gears?
Markie_D
Member #: 1660
Formally Mini_Uk
London
On 6th Feb, 2008 wil_h said:
drop gears?
How would i tell ? this happens when the cars not moving..
Cheers.
Shit Happen's
Does this happen when you push it in gear, or in neural?
Markie_D
Member #: 1660
Formally Mini_Uk
London
Happens when in nautral, but goes when clutch pedal is down ?
Cheers..
Shit Happen's
Are they straight cut drops? If so they do make a racket when spinning under no load.
Putting in the clutch stops them spinning and so the noise stops.
Markie_D
Member #: 1660
Formally Mini_Uk
London
They are straight cut drops gears.
If thats the case, do all u guys who have drops gears on there minis sound the same when in nautral ?
When on axles, the wheels would spin round while in nautral.
I reversed the car back, but got stuck in reverse. so we pushed the car forword a little which unstuck em. hmmm ?
Drives forword in 1st 2nd 3rd and 4th ok.
Shit Happen's
Have you adjusted the clutch correctly? Could it be the release bearing dragging?
Paul
Markie_D
Member #: 1660
Formally Mini_Uk
London
Paul
I adjusted it by the book *oh well* ?
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
Could it have something to do with the verto clutch throw out stop need adjusting ?
just not sure that it's the drop gears.
Could be wrong. ill have to make a recording tomorow, so u can hear..
This is a pain in the ass the reverse getting stuck also.......
Anyone near kent *wink* ?
Shit Happen's
turbo hogster
Member #: 178
stowmaket suffolk
just the drop gears rattling mate, it will be even worse when she is hot
Markie_D
Member #: 1660
Formally Mini_Uk
London
But it sounds like a rubbing noise, and not so much a rattling noise.
Ive seen 2 mini's that had drops, and they didn't make the same noise my is making.
So if thats the case, then why would reverse get stuck as im backing out mate ? but gets unstuck once the cars pushed forword.
So do all of you guys have this same noise.
Fuck, i thought it just wines when on the move, not sound like it's rubbing while standing still. sounds shite and if somethings wrong lol but i do like the wine once on the move.
Cheers..
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
yep im sure it's the drops gears *blush*
Does the rubbin noise go up and down while your revin the car ? as mine doe's.
That normal.. ?
Shit Happen's
