Home > Introduce Yourself > Hi all
miniboo
Member #: 2253
Las Vegas, Brit in the States
Hi to everyone,
I have been lurking on here for some time reading all the k head threads mainly.
I thought i better register now that i am actually going ahead with my build.
my block is in the machine shop and they are going to map it out as to whether i will be able to get the bores even enough to fir the K100 head. only going to be NA for now but things may change with time!!
here are some pics:
head and block
cleaned and media blasted naked block
its going in this
Edited by miniboo on 8th Feb, 2008.
hi and welcome to turbominis, where are you from ?
please update your sig!
using your controll panel
that block looks supebley clean
i hope you pull all the 6 plugs and flush them to remove ALL the blasting medium
anyway..... A WARM! WELCOME BUDDY
miniboo
Member #: 2253
i live in Las Vegas at the moment. the guy in the machine shop did all the cleaning work and i think they put it in a washer afterwards aswell but i will check. tbh they said the plugs were ok but i guess for th cost i should put new ones in.
Welcome mate!
T3Tone
Member #: 252
Sunny suffolk
Hello and welcome
-MINI CLUBMAN 1380 TURBO-
antman
Member #: 358
Snetterton, Norfolk
Hi miniboo, good to see you on here. Keep us posted on your build from whaty JohnK was saying your machine shop seems to have some good ideas.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Welcome miniboo
On 19th Jan, 2010 wil_h said:
Welcome aboard :)
