Home > Help Needed / General Tech Chat > That funny noise has gone lol
Markie_D
Member #: 1660
Formally Mini_Uk
London
After hearing some funny noise coming from the cam.
(No not drop gears lol getting used to that now).. :)
I had to find out what was going on. took cam cover off, and found that this thing (in the pic) thats meant to stop the cam belt coming off, was moaning like a whore *tongue*
So took it off, and heaven.
I know the drop gear over power it, put i can hear the thing rattling when the clutch was down...
Anyway.. this thing is loose for some reason//
Would it be ok to leave it off ? it was about 4mm away from it, and the cam cover will stop it coming off right ?
Shit Happen's
that stops the belt walking off, leave it off at your peril!
how and why was it making a niose?
are you using a minispares cap hed pulley bolt with either a KAD or Specialist components crank sensor kit?
If so, and that disc is loose, there is no compression on the pulley by the bolt, due to the threads on the bolt itself bottoming out.
I had to grind the first few threads off the bolt to get mine to clamp up properly.
sounds like your damper pulley isn't pulling right up as sprocket says! *surprised*
Removing that flange will cause the drive pulley to float accross the crank where it isn't being clamped into place and cause the belt to come off.
Markie_D
Member #: 1660
Formally Mini_Uk
London
I just noticed there were grooves on The inside of the cam cover, made by The disc.
*blush*
What a Cock!!
I didn't think about this happening.
Oh well, all part of learning.. wanker lol
So i guess ill have to make the cover stand out pround abit.
so, should i put some washers on the inside on the holes on the cam cover, to make it stand out, which will give me the clearance ? would that be ok ?
Cheers.
Shit Happen's
SumpNut
Member #: 28
If you had 4mm clearance between that and the belt can it not simply be just turned round, so it sticks inwards?
Markie_D
Member #: 1660
Formally Mini_Uk
London
No mate..
Ive sorted it now :)
Shit Happen's
What was causing it to be loose?
