| Home > Help Needed / General Tech Chat > Turbo smallbore and 12G295 | |||||||
48 Posts Member #: 1748 Member Forum Graffiti Queensland Australia |
9th Feb, 2008 at 04:27:07pm
Hi guys,
9th Feb, 2008 at 04:37:49pm
Sounds good to me.
9th Feb, 2008 at 04:47:38pm
On 9th Feb, 2008 Paul S said:
Sounds good to me. I'm using 31mm inlets and 26.5mm exhaust valves. You could push the inlets up to 33mm. If you go bigger on the exhaust, then you may need block cutouts, depending on your max valve lift. |
9th Feb, 2008 at 04:56:25pm
On 9th Feb, 2008 spraycanmansam said:
Cheers, How big can one go with the exhaust valves on a smallbore head without having to pocket the block? The 12G295 flows a fair bit more than a normal smallbore head so I don't think ( at this stage ) it's worth my time or money to go reshaping the chambers and porting the shiz out of it... or is it? lol I forgot to mention I was going to get them to do a 3-angle valve seat for the intakes and 30deg seats for the exhausts, thoughts? My long term goai is to achieve 160 engine horsies which I think is attainable with enough boost and heat control. I know there's a member on here with an 1100 turbo making 140hp, heck I'll even be happy to get that!
I think that 26.5mm exhaust are the biggest without pocketing, but it all depends on your valve lift and how much the head has been skimmed. If the valve face sits 0.35" below the chamber as mine does, then you can use bigger valves if the valve lift is less than 0.35". It is possible to fit 29mm exhausts. I would unshroud the inlet valve, particularly if you are going to use 33m inlets. Don't bother too much with the ports. 3 angle valve seats are good. I don't know about 30 degree on the exhaust though. 160hp is attainable, but it may take a bit of development. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Feb, 2008 at 05:06:49pm
Ok good to know. I'm going to be using an RE13T camshaft, I'll have to get the specs. The heads bog standard, never been skimmed. I'm going to get it lightly skimmed, just to make sure it's all flat :)
9th Feb, 2008 at 06:00:20pm
i have fitted 33mm inlet stainless race valves and 29.5mm exhausts stainless race valves in a 295 head de shrouded the chambers for the valve size in question
9th Feb, 2008 at 11:27:23pm
Don't use 30degree seats. The centering will be rubbish, and the seats will wear out. I'm fitting A+ inlet valves as exhausts in my own 202. That'll be excellent along with Rimflo 31,8mm inlets. There is no reason to fit bigger valves than 31ish. The head won't flow air for more, but it's very cheap and crude to fit big bore valves. On 13th Jul, 2012 Ben H said:
10th Feb, 2008 at 03:50:35am
Okay so scratch the 30deg seats. So with the 45deg seat they just cut a straight 45deg angle, not 30/45/60(?) like a 3-angle? Do they blend it in at all?
10th Feb, 2008 at 10:15:16am
Think about it as 'how much valve lift can i have before it hits the block.'
10th Feb, 2008 at 10:27:05am
On 10th Feb, 2008 spraycanmansam said:
I'm thinking 31mm inlets and 29.5mm exhausts... No point in going that big with the exhausts. 26.5mm will do just fine. I use 1275 A+ plus valves, turned down to suit and a spacer under the spring to accomodate the extra length. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
10th Feb, 2008 at 10:45:31am
IIRC the RE13T is basically the same as the N/A version just with a lot less overlap. I think the lift is around .380" or more? I'm using 1:3:1 roller tip rockers as well which will bump it up a bit higher...
152 Posts Member #: 2190 Advanced Member South Carolina, USA |
10th Feb, 2008 at 03:18:44pm
Where are you going to purchase the RE13T? Have have searched but been unable to find them online. How much do they typically go for? |
10th Feb, 2008 at 03:53:56pm
10th Feb, 2008 at 05:12:33pm
i think the re13t is just the re 13 with a wider LCA, if so calver can do them as he does the RE13's with custom LCA's depending on the engine.
10th Feb, 2008 at 10:16:51pm
Okay so scratch the 30deg seats. So with the 45deg seat they just cut a straight 45deg angle, not 30/45/60(?) like a 3-angle? Do they blend it in at all? The valve seats should be 3-angle, or even better radius, what I use. A straight 45 angle looks shit, flows shit, like this: What would you prefer? This head I just received. I'll get some pictures up when it's done. Valves should be modified like this: However It sounds as you're fitting Minispares race-valves, that means they don't need backcutting. On 13th Jul, 2012 Ben H said:
11th Feb, 2008 at 09:01:11am
Ok went to talk to the fella doing my head today. I had the head cleaned and crack tested and it has a few cracks in one of the seats, but that'll be fixed with new seats.
11th Feb, 2008 at 03:34:56pm
On 11th Feb, 2008 spraycanmansam said:
Ok went to talk to the fella doing my head today. I had the head cleaned and crack tested and it has a few cracks in one of the seats, but that'll be fixed with new seats. Well, depends on how deep the cracks are. I just binned a cracked 202 head. Dropped valve seat inserts are a nag. On 11th Feb, 2008 spraycanmansam said:
I had a look on Mini spares and couldn't find any 31.75mm inlet valves but I found some 33.3mm stainless ones which I'll get him to turn down to 31.75 mm. NOOOO! These are big bore valvesm and too long for your application. Get the proper ones. Minispares have got four 31,8mm Rimflo valves in stock at Potters bra. Call them
11th Feb, 2008 at 04:11:30pm
Apparently the cracks in the seat were only minor and he thinks it'll be no worries with new inserts, fingers crossed...
11th Feb, 2008 at 05:21:43pm
C-RIM104 from the top of my head :) Those exhausts are perfect!! On 13th Jul, 2012 Ben H said:
