Home > Help Needed / General Tech Chat > Plumbing in leccy water pump and external bypass thermostat
Righty then, ive drawn a diagram of what I plan to do and im after some input/advise from you guys, whether you think this will work or if there is a better solution to where hoses are connected?
Matt
bollox is the attachment coming up?
Ian_W
Member #: 40
Stratford upon Avon
no its not mate.
Ian_W
Member #: 40
Stratford upon Avon
posted on behalf of matt as his computer is shite...
Cheers mate..
I still can't see it just a cross as dial-up doesn't seem to like photobucket! lol
Doesn't make much odds to me as I have the original though. *laughing*
Main concern is the expansion, hose? Will the pump try and draw from this and cause cavitations? On the other hand if I move it to the pressure side of pump will it over pressurise the expansion?
EDIT: another valid point Ian has made is about the water returning from the turbo will this cause the thermostat to open to early?
Edited by matty on 11th Feb, 2008.
I had strange results from my water cooled turbo,,, Best way - if possible - is to return the water out of the turbo into the top of the radiator via its own pipe.
So long as the electric pump is as low as possible - ideally below the water jacket in the block - it shouldn't cause any problems I reckon...
Ah right...Still haven't decided on pump yet but there should be enough room to mount it on the subframe so no problems with getting it lower than the water jacket.
So do you think it is ok to have the expansion hose on the same side of the pump thats drawing as opposed to the pressure side?
What do you mean?
how does that 3 port thermostat work matt ? is there any chance of it all going down the bypass pipe into the pump and not through the rad at all ?
also have yoiu forgotten the heater ?
In that drawing the hose going to the expansion tank is on the side of the pump that with be drawing in water and im unsure if the pump will try and draw water from the expansion tank aswell causing cavitations?
On ther other hand if I put the hose going to the expansion tank on the pressure side will it over pressurise it causing it to let water out of the cap?
I know on a the "normal" setup with mechanical pump, I had the expansion tank coming off the heater hose and it was fine but that also had water coming from the heater matrix going back into the bottom rad hose so it always had a supply of water so if it were to draw water from the heater hose it would never cavitate? *oh well*
If that makes any sense? Lol
I believe they work by having an inlet at the bottom and it exits at the side. When open the water passes straight through. Im not 100% certain if it shuts off the side exit or not? I assume it does shut the side exit as it wouldn't have any function like you say and would completely bypass the rad. Hopefully it should arrive in the next couple of days and it will become clear.
Heater AKA turbo!! lol Weight saving *wink*
The bypass thermostats shut of flow to the bypass port as the thermostat opens to the radiator
Ah cool, if thats the case this setup should hopefully be ok!
The expantion tank is plumbed into the suction side of the pump and the vent plumbed into the highest point of the cooling system, usualy at the top of the head before the thermostat. this will force the air out at the top and the coolant in at the bottom. As Dave said, best to plumb the turbo return into the top of the rad after the thermostat.
Ok that makes sense. Would it be ok to run a bleed from the head outlet pipe and tee that into the rad vent and run them both to the expansion?
hario
Member #: 2885
If the high pint of the vent in the radiator has a low point between it and the expansion tank then it will remove any air bubbles that might form there. Good idea I say :d
