Home > Ebay items For Sale > Bit Steep for a Head Gasket
These any good?
http://cgi.ebay.co.uk/Cometic-Mini-A-serie...1QQcmdZViewItem
Coupe
Member #: 2178
Leyland, Lancs
Cometic are usually very very good.
I've just paid £90 for a pressed steel headgasket for mine, but I'm told its practically bullet proof but should be ok!
The make (Cometic) have a certain reputation, deserved or otherwise, but from this Seller.. "compressed thickness .0030" and can withstand high compression."
Well, if the gasket compresses to 3 thou I'd be a bit concerned about what it's made of...
LOL,
he means .030"
Generally speaking, Cometic are very good.
And if surface prep is good, a MLS head gasket will stay intact at much greater pressures than a regular composite type ever will.
Its just a pity the Cometics in some ways are so dear.
Cometics for an LS1 are about $80-100ea
The standard GM ones are $30 each, and will handle 1000bhp lol
On Subarus, they can handle 500 without any worries.
ive seen a cometic burn through beyween 2 and 3 after 3 runs on nitrous,
£70 is small change, my new HG just cost me £160, hope it works,lol
is it Ti carl?
talking of subarus my dealer quoted me £280 for a head gasket set, i wnt to BGA got the headgaskets at £18 a side and bolts at £34 they seem to be good quality
The old composite gaskets Subaru used are very cheap. The MLS are about 2-3 times the price.
A head set on a Subaru would be a waste of money though. Most important bits are HG obviously, and the rubber washers under the valve cover bolts, as these go soft with time, and the rocker cover ends up leaking due to not being tight enough.
