| Home > Technical Chat > Piston Design | |||||||
48 Posts Member #: 1748 Member Forum Graffiti Queensland Australia |
13th Feb, 2008 at 07:28:18pm
Ok so I'm really interested in what makes a piston good for turbo applications...
2497 Posts Member #: 1954 Post Whore Luton Bedfordshire |
13th Feb, 2008 at 07:32:43pm
It has to be able to deal with the heat above all so start thinking ceramic like the germans do. Own the day
152 Posts Member #: 1074 Advanced Member Northamptonshire |
13th Feb, 2008 at 07:46:13pm
What is wrong with a decent omega forged piston and a decent amount of undercrown oil cooling unless you are going to use huge boost but then something else will probably be the limiting factor.
13th Feb, 2008 at 07:46:44pm
But you live in the land where the best small bore pistons are made, and they're cheap too. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
13th Feb, 2008 at 07:52:51pm
Yeah I know, but most pistons for smallbore's are for NA applications... How many dedicated Turbo pistons have you seen for a smallbore? On the other hand, there's tons for big bores!
13th Feb, 2008 at 08:02:34pm
There are many issues with designing a piston as you may know if you are contenplating designing one.
13th Feb, 2008 at 08:02:46pm
13th Feb, 2008 at 08:12:30pm
On 13th Feb, 2008 spraycanmansam said:
Yeah I know, but most pistons for smallbore's are for NA applications... How many dedicated Turbo pistons have you seen for a smallbore? On the other hand, there's tons for big bores! I'm sure people said "why bother turboing a 998, get a 1275!" ... but we all know how fun that can be.. I'm sure there are good pistons out there.. I'm just curious as to what would make the perfect piston. Someones gotta experiment! 8) I know what you're saying, but the Hypetecs have proved 100% reliable even in 998 engines producing over 150 bhp, so how much more perfect can you get. The only differance between a turbo and an NA pisyton for the large bore engines is that they have bigger dishes as far as I am aware. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
13th Feb, 2008 at 08:25:10pm
If you really must design your own , a version of this one would probably have the best specific performance (strength/weight ratio) when fully optimised
13th Feb, 2008 at 08:25:53pm
I've got a set of Hypatecs sitting beside me! Edited by spraycanmansam on 13th Feb, 2008. |
3596 Posts Member #: 655 Post Whore Northern Ireland |
13th Feb, 2008 at 10:03:33pm
Why not just get a set custom made ?
13th Feb, 2008 at 10:09:09pm
TBH I found my copy of AutoCAD again and wanted something to do |
13th Feb, 2008 at 10:41:06pm
Dont get me wrong, they're reputation speaks for itself.. 'benjamin''s putting out 140hp with them, they just don't 'look' like they were meant for turbo... get a marker pen and write 'turbo' on them LOL also, what cr you going for, you can easily get a 998 down to the high 8's by just bolting on a stock 295, im sure with a bit of work even lower cr's would be possible....so why fuck about with piston dish/height and risk losing any squish? also, the whole bigger=better re. ring lands issue is debatable too Im not saying dont do it, im sure it would be load sof fun to design a perfect piston and have a 5 axis master spit one out, but is it really worth it? Either way, good luck with it Joe "Turbo's make torque, and torque makes fun"
14th Feb, 2008 at 08:08:44am
Haha, I may just do that...
1425 Posts Member #: 690 Post Whore Norfolk |
14th Feb, 2008 at 12:47:39pm
You must also remember that pistons are not round pieces of alloy all the way down their length - how will you determine what the skirt/ crown expansion with temp will be for "your" design - hence allow for this in the initial design to machine parts from?
If Carling made Mini engines
14th Feb, 2008 at 01:36:03pm
Hasn't anyone watched "The Indian?" All I have to do is make a mould and pour the melted metal in and I'll have a landspeed record breaker!! |
81 Posts Member #: 934 Advanced Member halifax, west yorks |
14th Feb, 2008 at 02:21:23pm
"the worlds fastest indian" melt some old ones down and jobs a good un' |
152 Posts Member #: 2190 Advanced Member South Carolina, USA |
15th Feb, 2008 at 03:51:50am
I just went through the same trouble trying to find pistons that I liked for my 1098. I finally gave up and decided to have some made to my specifications…we will see how they work once I get the car back the road.
15th Feb, 2008 at 09:57:15am
I found it a worthwhile excercise cading a piston, I did it to see how much the pin could be moved up the piston and still keep a decent dish and ring positions.
15th Feb, 2008 at 10:44:41am
yes this is the reason why mini pistons are hopelessly heavy too. too much metal above the pin. Longer rods or a block skimmed 7 mm would help, together with custom pistons. |
15th Feb, 2008 at 10:48:50am
15th Feb, 2008 at 10:49:58am
yes, but that will make the engine less rev happy. Light pistons are more important on a revver. |
15th Feb, 2008 at 08:28:26pm
I'm also a bit skeptical about my Hypatecs... Dont get me wrong, they're reputation speaks for itself.. 'benjamin''s putting out 140hp with them, they just don't 'look' like they were meant for turbo... I'm thinking of getting some 998 versions and milling a bit off the top and a dish. They have thicker ring lands and look sturdier... stevieturbo that's a good price for custom made... do they design it and you just give them a few details? I just gave them bore, dish etc, and the rest is based around typical LS stuff, which meant I didnt need to put much thought into it. Any if the big name Piston suppliers can do it though. I opted for JE this time, before it was Ross, next time I think I'll go for Wiseco. There are Mahle, Accralite, Arias, Custom Pistons ( CP ) and no doubt plenty of others too. 9.85 @ 145mph
