| Home > Help Needed / General Tech Chat > Wont Fire - Problems with starter solenoid | |||||||
50 Posts Member #: 2250 Advanced Member Stockport Manchester |
14th Feb, 2008 at 04:52:02pm
At the moment the starter solenoid is just "clicking" tried the spanner on the two terminals, not even a spark.
14th Feb, 2008 at 04:56:51pm
I assume the battery is actually charged.
14th Feb, 2008 at 05:01:33pm
Its being jumped off my 4x4 (2.9TD so should be good enough)
14th Feb, 2008 at 05:01:34pm
Double Post
Edited by Double_Wax on 14th Feb, 2008. |
14th Feb, 2008 at 05:10:02pm
If that reading is while the solenoid is being operated and using the same earth point, then your solenoid is chuffed. |
14th Feb, 2008 at 05:14:28pm
Thats reading with ignition on.
14th Feb, 2008 at 06:35:51pm
but if you jump across the posts with a spanner and it still doesnt work it cant be the solenoid.
14th Feb, 2008 at 06:57:02pm
Thats whats so annoying.
![]() 76 Posts Member #: 2043 Advanced Member |
14th Feb, 2008 at 07:16:13pm
jus put a jump lead straight to the starter motor, just to get it running tht is! |
15th Feb, 2008 at 11:30:51am
Think its the starter motor, just whipped it off, going to rebuild it now.
15th Feb, 2008 at 11:54:48am
before you pull it apart stick it across a batery and see if it spins up On 28th Aug, 2011 Kean said:
15th Feb, 2008 at 01:21:22pm
Opened starter, missing 2 bushes!
