Home > Help Needed / General Tech Chat > A couple of questions to finalise the spec of the engine and gearbox.
Right. This summer I will be turboing my mini, I now have pretty much all the parts I need. This will be my first engine build so want to get everything right first time.
I nearly have the spec sorted but just have a couple of questions to finalise it.
Spec.
1275cc standard bore, Turbo pistons - rebuilt - balanced rotating assembly
N/A mg metro cam - if I can source one
std turbo head
vauxhall van intercooler
8- 8.5 psi boost
std t3 with modified elbow
std turbo dizzy - mk1, megajolt mabie added at a later date.
With that little lot I am looking for 105 ish banannas
I am trying to decide what to do about the clutch and gearbox side of things.
The drop gears I may leave standard, If I can afford straight cuts I will.
minispares 4 pin diff.
Will a verto clutch set up just about hang in here? Or shall I not chance it and go for a pre verto set up? The thing is I don't want to balance everyting with the verto flywheel and then throw the balance out by needing to fit a pre-verto set up.
I'm just trying to finalise things in my head now.
Thanks
Edited by minimole23 on 14th Feb, 2008.
welshdan
Member #: 1111
s wales
where bouts in bristol r u minimole? do u drive a mini at the moment? i live and work down here now
blockshed
Member #: 2168
If you have your crankshaft assembly balanced correctly with the verto clutch assembly , when you change to a pre - verto AP set up you just have to get the new flywheel assembly balanced .
Job done
I thought it is good practice to have the crank and flywheel assembly balanced as one. If that is not the case I may see if the verto set up survives.
If it slips then I will have to go pre-verto and have the flywheel assembly balanced individually then.
Welshdan I only go to uni in Bristol. After spending a large amount of cash restoring the car, I am leaving it safely tucked up in the garage at home - Near salisbury.
The reason I am planning all this now is that I need to strip my spare 1300 engine so my machine man has plenty of time to hone, balance stuff ect. He is busy.
welshdan
Member #: 1111
s wales
uwe or the real uni?
I ran 15psi with a Verto and it never slipped once The helical drops disintergrated though.
Monster22
Member #: 39
Hang on.... UWE is a real uni......
Lol looks like I've started that debate again. Yep I go to UWE.
blockshed
Member #: 2168
If you have a crankshaft that is perfectly balanced ( zero balanced ) , then you fit a flywheel to it and balance it correctly both are perfectly balanced .
If you then swap the flywheel for another perfectly balanced one , the flywheel assembly will still be perfectly balanced .
Inbalance can be caused if flywheel / clutch / pulley etc is not fitted in exactly the same radial position as the one it was balanced in . This does not normally apply to mini engines as the parts only fit one way .
welshdan
Member #: 1111
s wales
ha.iv just finished at uwe...
