| Home > Help Needed / General Tech Chat > Removing broken bolts | |||||||
15th Feb, 2008 at 11:41:20am
This may well turn in to a good how to, anyway here is my problem.
15th Feb, 2008 at 11:51:57am
Hmmm,
15th Feb, 2008 at 12:23:04pm
mate, just check using a punch to knock bits of drill out. doesnt matter if you goose the hole as the helicoil will cover it.
15th Feb, 2008 at 12:24:12pm
the best option is to EDM - electro spark it out. but since its a big item that wont be so easy to get done. |
15th Feb, 2008 at 12:44:51pm
I was going to suggest EDMing, but it may cost a bit! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
15th Feb, 2008 at 01:12:56pm
Jim - spend 10 quids worth of time on it, after that, don't bother with it. These are a much easier olution.
![]() 2102 Posts Member #: 432 Post Whore Swindon |
15th Feb, 2008 at 01:59:32pm
can't you just buy an ultimate engine steady lol |
15th Feb, 2008 at 02:12:43pm
cheers guys, I'll try and have a play, but may well fall back on daves method On 15th May, 2009 TurboDave said:
15th Feb, 2008 at 02:14:30pm
Ah they look just the ticket..every day is a school day! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
15th Feb, 2008 at 02:29:34pm
miniturboman
15th Feb, 2008 at 03:47:52pm
i see gavin @ mini spares is reading this thread. expect turbo dave to get extra discount from now on!
15th Feb, 2008 at 03:56:29pm
i've heard that if you just use the ultimate engine steady with out the normal top steady it can shear you thermostat bolts? |
15th Feb, 2008 at 06:12:53pm
daves answer is the one
15th Feb, 2008 at 07:20:06pm
is it an engine mount or the steady,?
15th Feb, 2008 at 07:23:30pm
its a steady carl, pics over the flywheel housing cheap fix..... minispares keeps the ideas & goods coming for the right price
15th Feb, 2008 at 07:33:50pm
i know what dave has posted shows an engine steady repair, but jim said engine mount, so which is it, |
15th Feb, 2008 at 07:43:17pm
there is no engine mount in the block though!
15th Feb, 2008 at 07:45:51pm
i also have a problem with a broken bolt.. the only problem it is in my turbo, it is sat a few mm down from flush where the elbo comes off.. would i be able to drill this out? are there any other ways like re screwing in the bolt and pushing it out? or somthing. i dont particually want to drill it out and re-tap it :( Drives
15th Feb, 2008 at 07:52:20pm
drill it out and re tap it, easy. or helicoil. i did the same bolt. i think it was M8 from memory so easy to come by.
15th Feb, 2008 at 08:27:56pm
Carl, steady on fella!! lol
15th Feb, 2008 at 08:31:44pm
8.2mm so my book says which sounds about right.
