Home > Help Needed / General Tech Chat > help intercoolers!
t3gav
Member #: 229
Gavin@minispares.com
kent
sorry to be a pain but could someone explain more about the fitting of a intercooler, all the pictures i seem to see have the pipe going direct to the plenum do you guys modify the plenums yourself or can you buy them ie like the dumpvalve avonbar one etc, also how much extra stress do they put on the engine? any help would be great thanks.
An intercooler goes between the compressor {alloy} side of the Turbo and the plenum. Is is basically a radiator which cools the compressed air from the Turbo before it enters the engine, thus providing a denser charge.
An intercooler does not put any stress on your engine in any way.
You can make an adaptor for the plenum or modify the existing one like this -
Hope this helps.
Phil. *smiley*
t3gav
Member #: 229
kent
cheers mate your sites great, helped a lot!
t3gav
Member #: 229
kent
sorry mate still confused, if the intercooler lowers the intake charge temp surely it means denser air bigger boom etc etc, so how come no extra stress on engine? saw the plenum modified take it the ic goes to the plenum and where the original plenum pipe was joined.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
dont know, but its less heat, surely heat is also a big consern too :)
Mirage
Member #: 119
Turbo has to work a bit harder so a liottle more wear and tear here.
Can also help to prevent detonation.
