Home > Help Needed / General Tech Chat > my fucking brakes!
stevenford_uk
Member #: 144
went up the road again today in me mini, the fuckin brakes went straight to the floor again! i have now bled them up about 5 times, nothing seems to work, i will get a real solid pedal when the car is not running but as soon as it starts the pedal goes wank, so i desconnected the servo pipe, the padal went to the floor! its really pissin me off now, cos if i cant get these working then i cant go avon park!
can anyone please help!
pete
Member #: 275
bonie scotland
if you have the ruber flexi brake pipe. get 4 brake clamps or 4 vice grips, clamp on 1 flexi at a time test brake pedal, till you test all 4this will tell you if its wheel cyl calipers or master cyl ie if pedal is solid with 4 clamps its wheel cyl or caliper, if it goes to floor its master cyl. olso you can put your hand ontop half of brake pedal, feel if any brake fluid on pedal, any way brakes hold you back????????????? good luck
evolotion
Member #: 83
Glasgow, Scotland
Had this issue, was resolved with a master cylinder rebuild kit. :)
Denis O'Brien.
I'm starting to think master cylinder/servo assy Steven...
You've tried a lot, and you're obviously doing things right to be getting a 'pedal'.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
master cylinder...
rebuild rearly last either... and they are about ?100 thou...
Alex
AlexF
stevenford_uk
Member #: 144
problem found!
i put two blanking bolts into the master cylinder/servo and the pedal would not move, so it was not that, but then as i got out of the car i noticed my rear wheel paint was beginning to peel, so off came the wheel, and drum, pulled back the rubbers, sure enough, nackered brake cylinder. will be changing it today, goin for mot tomoz.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
fingers crossed for ya!
alex
AlexF
Nick
Member #: 154
Midlands
best get the blowtorch on the inside of the drum then dude :) easiest way to get rid of the fluid.
Use Genuine cylinders only - I've not had much luck with budget ones lasting more than a few years!
stevenford_uk
Member #: 144
the cheapest will do for the mo, just as long as i get to avon park.
there was no fluid on the inside of the drum, the rubber completly sealed the leak from the outside world, there is no trace of it with the rubber on!
thats why i didn't see it first time round
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Then I'd be amazd if thats what sent your pedal to the floor...
a slight weep normall just lets air in and you end up with a spongy pedal.
AlexF
