| Home > Help Needed / General Tech Chat > Fitting rad with split cowl | |||||||
928 Posts Member #: 65 Post Whore South Yorkshire |
19th Feb, 2008 at 09:38:34pm
What's the knack to fitting the radiator with the early split cowl? From reading the haynes book I'm thinking fit the fan, fit the bottom half of the cowl, slide the rad in (not sure on this bit as already had the bottom hose oulet stuck again the cowl) and bolt it to the bottom half of the cowl, then fit the top half of the cowl. Would this work?
19th Feb, 2008 at 09:43:33pm
Ive always fitted it as a complete assembly after fitting the fan
I seriously doubt it! |
19th Feb, 2008 at 09:50:58pm
I tried that but couldn't get it all the way past the fan and got stuck on the bottom corner of the cowl thing on the inner wing.
45 Posts Member #: 446 Member Burntwood Staffordshire |
23rd Feb, 2008 at 12:11:16am
Sounds good but you will need a cut down spanner to fit all the bolts. |
23rd Feb, 2008 at 05:47:57pm
23rd Feb, 2008 at 07:42:26pm
Has it gone in as one with a plastic fan?
23rd Feb, 2008 at 07:49:52pm
I fit the bottom part to the engine mount loosly, fit the top part to the rad, slide the rad in, add the other fixings loosely then fit the bottom & top hose then tighten everything.
