| Home > Help Needed / General Tech Chat > short flat spot when flooring the gas | |||||||
263 Posts Member #: 115 Senior Member Austria, near Vienna |
11th Jul, 2004 at 08:35:32pm
Has anyone made the same experience?: I have a short (maybe 0,5-1sec) leanout when flooring the gas pedal. On my wideband lambda meter I can see that the AFR goes to 15:1, then comes down to 12,5-13:1. It is just a for a very short time, and if I had not the lambda reader it would have count it to turbo lag. But as soon as the AFR goes to the 12,5-13:1 you can feel how fast the turbo spools up, so I want to get rid of this short leanout. On my n.a. engines I can see that the mixture even richens to 12:1 (for about 1 second) when flooring the gas. But on the turbo the opposite happens. What do the lambda meters speak on your turbo engines when flooring the gas? Any ideas what causes the problem? Thanks! Harry Bimmer Twinky headed and turboed A-Series:
11th Jul, 2004 at 09:41:42pm
Have you tried blanking off the "part throttle lean out pipe" on the carb ?
12th Jul, 2004 at 09:10:21am
Almost definately this pipe...
12th Jul, 2004 at 05:58:59pm
I blocked this pipe already. But maybe it is not 100% leakfree - I will doublecheck! So your lambda reads a short enrichment when flooring the gas? Bimmer Twinky headed and turboed A-Series:
12th Jul, 2004 at 06:18:21pm
Still does it even now...
Edited by turbodave16v on 12th Jul, 2004. On 17th Nov, 2014 Tom Fenton said:
12th Jul, 2004 at 09:55:51pm
I can see the short lean condition on the wideband AND the narrowband lambda readers. I run them parallel at the moment, because I wanted to see where the limit of the narrowband sensors is. BOTH show the same leanout! (short, but definitly there!) Bimmer Twinky headed and turboed A-Series:
