| Home > General Chat > 13 inch Wheels | |||||||
![]() 514 Posts Member #: 2169 Post Whore Malta (Ex. Scotland) |
20th Feb, 2008 at 06:47:37pm
Am I right in believing these aren't the best for standing starts?
Warning:Stig in Training
20th Feb, 2008 at 07:15:19pm
A 4.1 will give you lower gearing, i.e. the lower the number the higher your top speed. I have been thinking about this, the only problem I saw with a mini geared for top end (not so much for top speed but for crusing comfort) is the sc/cr gearsets have a tall first. On 7th Nov, 2008 Nic said:
20th Feb, 2008 at 07:37:13pm
The 13" inch wheels are not much bigger than 10s.. Go out and measure. On 13th Jul, 2012 Ben H said:
20th Feb, 2008 at 07:45:42pm
Actually V it's simple math.
![]() 20 Posts Member #: 2192 Member Huddersfield |
20th Feb, 2008 at 08:06:53pm
10 vs 13 pretty close due to high side profile vs low?
20th Feb, 2008 at 08:48:38pm
check the rolling circumferance of a 165/70/10 against a 175/50/13 - not much in it |
20th Feb, 2008 at 09:44:31pm
The TT on 13s with 20" tyres (much taller than any road tyre that you would use) tops out a 110 @ 7k with a 4.1. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
21st Feb, 2008 at 07:39:56am
Yeah I didn't make it very clear. You mentioned 4.1 and top speed together so I figured you were gearing for top speed with a 4.1. I take it you mean using a shorter diff to counterbalance the bigger circumfrence of 13"s? In that case as V has said there isn't a hugh difference between 10"s and 13"s, not enough for a 4.1 anyway!
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
21st Feb, 2008 at 09:24:19am
On 20th Feb, 2008 El Potter said:
Am I right in believing these aren't the best for standing starts? And would using them in conjunction with a 4:1 diff to give some top speed be a mistake? It's just that I saw this purple Turbo Mini in MiniWorld on 13" Revos and it looked sooooo good I got to lusting after a set again
Thanks Tom this one??
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
22nd Feb, 2008 at 05:20:25pm
Yup that's the one Rubicon.
Edited by El Potter on 22nd Feb, 2008. Warning:Stig in Training
24 Posts Member #: 2273 Member middlesex |
25th Feb, 2008 at 11:31:18pm
isnt that mini turbo petes one?
