| Home > Help Needed / General Tech Chat > Mk1 floor dip switch current? | |||||||
22nd Feb, 2008 at 05:35:55pm
Would anyone happen to know the current rating of the mk1 floor mounted dip switch?
22nd Feb, 2008 at 05:39:48pm
When I've used 80/100W bulbs in the past I've always rewired using relays. If you mount them in the engine bay on the drivers side inner wing you can take the high current power source from the starter solenoid terminal that is linked via heavy gauge cable direct to the battery. I also reused the existing cable, this is quite thick and up to the job, it is just the main switch and stalk that gets into bother, this is on later cars though, so you'll need to check the wire gauge on a Mk1.
22nd Feb, 2008 at 06:50:32pm
As Tom said run some relays. On 19th Jan, 2010 wil_h said:
22nd Feb, 2008 at 06:59:42pm
Cheers Tom,
22nd Feb, 2008 at 10:25:17pm
The way I did it means you leave the majority of it alone, and then break into the loom as it comes down the inner wing. The original wiring now becomes the "signal" wiring for the relays, and the main power is sourced from the solenoid. When I did it I fitted 3 relays, one for dip beam, one for full beam, and one for the pair of spots I had on the car in question. Obviously the side lights still work as per normal.
45 Posts Member #: 446 Member Burntwood Staffordshire |
22nd Feb, 2008 at 11:52:20pm
If I remember the MK 1 headlights are connected by bullet connectors,so if you want to keep loom original extend back to a relay mounted by solenoid as Tom mentioned.Don`t forget to add fuse. |
23rd Feb, 2008 at 12:45:28pm
Cool cheers chap,
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
23rd Feb, 2008 at 11:08:00pm
where did you get that fusebox from then? |
24th Feb, 2008 at 11:14:41am
vehicle wiring products,
