Home > Help Needed / General Tech Chat > Suicidal torque steer
1380turbo
Member #: 1211
Working up the BHP ladder.
Ok still running the lil beastie in but with jus 4psi of boost the torque steer is a bit worrying!
Was out last night for a little blast and taking into consideration how greasey the roads are at the moment it was terrifying!
Coming of the power in any gear the car pulls hard to the left, i have been looking at the JK driveshaft kit but would be interested in hearing other peoples veiws etc.
Also does anybody know of some good tracking values (camber and toe) for both front and rear suspension.
Oh yeah, im running 12x6 deep dish rims aswell.
Ta guys.
well, those rims won't help, but its worth getting the suspension set up properly.
If you haven't had the suspension sorted, then you know what's causing it...
1380turbo
Member #: 1211
Top advice Vegard. Got some numbers for me?? *happy*
Ta guys.
'OFF' the power? surely not torque steer then?
6x12s should be no problem, the best wheels for a road mini IMO.
ahh but theyre DEEP DISH 6x 12's.
actually i didn't notice that you said it was when you come off the power.
after recent experience fist thing i'd do is jack up the passenger side and look for play, especialy in the steering rack.
once the geometry i sorted ,eg
parallel tracking ,1.5 degr neg camber 4.5 degr caster at front ,
.5 degr neg camber and 1/8th toe in at back ..
ride height 4mm off bumps at front level sill with rd (this setting can cause some tyre to arch contact on big bumps !)
the biggest cause of bad handling is too much offset on wheels , try to get at least 14mm inset (''ET''or positive offset ,as its known ,) on your wheels .
these setting worked well on my car . but everyone has a different style of driving and you can tailor it to your own style a bit too .
And I didn't notiice that they were deep dish. however is the off set that much more?
Mine was a pig until I had the tracking and what-not sorted. Fine now.
1380turbo
Member #: 1211
Coolio guys. I will get it down to the old Tracking shop and have a 4 wheel set up done with Roberts figures.
4mm? Jeez, why have suspension at all. There should at least be one or two centimeters of clearance here.. With this setting. there will be no suspending at all.
Sounds like you are over compensating for it pulling to the right when you put the power down!
vegard your completely wrong !*tongue*
Se7en
Member #: 446
Burntwood Staffordshire
Coming off power.
Check your subframe mountings,engine mountings,tie bar bushes infact anything that can be infected with poly
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Vegard is wrong! Do I not have suspension on my car Veg?
Ric
Member #: 36
Basingstoke
exactly the same as mine this time last week, was a nightmare to drive even on 4psi. Just had a cheapy quick fit setup to get it roughly right and it's tons better.
I'm with Robert on this one.
4mm? what will that equal? 2cm of suspension travel? I guess you'll be allright sitting in the garage looking mean, but out on the roads? British rubbish country lanes. Madness..
Mini63, you've got all your suspension in the tyres then!
well mine is less than 4mm and I use my car every day on British roads of all types and quality. Including speed bumps.
Drives and handles perfect
You can easily remove some weight of the car then, by removing the suspension cones and trumpets. No need! :8
miniminor63
Member #: 672
Oslo, Norway
you are actually both wrong AND stupid this time Veg*tongue* you know my car has suspension. you even commented it once, after trying it with the red spot cones....The ride height I have never changed, and it will stay like it is.
miniminor63
Member #: 672
Oslo, Norway
but then again. I am know to make VERY stiff suspension nice and comfy as if by magic *happy*
Edited by miniminor63 on 23rd Feb, 2008.
Ta guys.
Mine did exactly the same, turned out to be the tie rod not tight enough on the near side. Does it go round left hand corners really well but tries to go straight on right hand corners? lol
1380turbo
Member #: 1211
Hahahahahahaaha had a quickie look this evening and the evil Mini demons have loosened that same part *tongue*
Also a tiny bit of play in the top pivot so a little rebuild this week and i'll go from there.
