| Home > Help Needed / General Tech Chat > dry deck silicon joining hose | |||||||
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
22nd Feb, 2008 at 08:27:02pm
To make things a little easier with my 998 k100 build i decided to get the machine shop to dry deck it.
22nd Feb, 2008 at 08:28:59pm
should be fine, its the same size as the top& bottom hoses. On 28th Aug, 2011 Kean said:
22nd Feb, 2008 at 09:21:09pm
Inch would be up to the job, but the top hose on the K head is 32mm or 1.25" and what im using On 26th Oct, 2004 TurboDave16v said:
22nd Feb, 2008 at 09:35:02pm
well 1.25" is available from that seller as well so i will get that. depends on what the machine shop have done with regards to the core plug hole. i might drop in on the way to disneyland,CA today!! |
for mine
