Home > Help Needed / General Tech Chat > clutch not disengaging? - Seriously p***ed off.
apollo996
Member #: 1240
Worcester
I think my clutch isn't disengaging correctly as I can change gear without the clutch! Any suggestions? This happenned after I refitted the engine. I'm not sure it makes a difference but the car is on stands at the moment and I haven't tested if this happens under load (on the ground). Getting pretty fed up so any help appreciated.*frown*
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Checked linkage etc???? Sounds daft I know
On 19th Jan, 2010 wil_h said:
I think that that is quite normal.
The baulk rings will do the clutching for you.
Try it under load.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
good call Paul.
you can change gear with pritty much any car w/o using the clutch, i do it all the time as i am lazy, it doesnt damage the car if you dont force it in. its alot easyer with non strait cut gears (cant spel h******** gears lol).
Edited by Paul R on 24th Feb, 2008.
