Home > General Chat > MY CAR WORKS!!!!
jamesfawcett
Member #: 218
Bingley, West Yorkshire
RUNS! WORKS! STARTS! DOESNT STALL! its so smooth, just runnig wtih the MBC on 0, but thanks to turbodave's idea to pue a t piece from the plenum chamber to the antirun on valve takeoff to the regulator, it works perfect! It doesnt ever stop running though i have to put it in gear, but WOW theres nothing wrong!
MOT tomroow hopefully then! Avonpark may still be on!!!
Carl
Member #: 95
liverpool-on-sea
YYYYYYYYEEEEEEEEEEHHHHHHHHHHAAAAAAAAAAAAAAAAAAAA
is that a prmanent fix or does it tell what the problem is hope to see you saturday then *smiley* *smiley* *smiley*
jamesfawcett
Member #: 218
dont know! hopefully turbodave will let me know!
Arno
Member #: 233
Beugen, Netherlands
Congrats, well done, *happy* *happy*
Does that mean I can stop praying?
Good for you, One worry less.
Good stuff mate !! *smiley*
Phil. *happy*
Pretty sure it means that the internal passages of the carb are blocked and that it needs a rebuild IIRC.
Well done though feebs. Good to get it working at least *smiley*
clubman_dan
Member #: 142
Winchester
nice one mate, good to hear you got it all running
It can mean a few things - the pipe is blocked, the incorrect gasket between the plenum and carb, etc...
It is a 'temporary' fix, but one that's been in place on my carb for the last 2 years, as i just can't find anything wrong at all!!!!
It prob never stops because you connected the live coil to a permanent live on the fusebox, rather than an ignition live???
If u ain't got a meter, try a bulb earthed to the engine to figure out which spade to use!
jamesfawcett
Member #: 218
oh bugger. I havent been to start my car this morning, but yes i have. I connected the coil straight to the starter motor feed (the big battery cable, along with the fuel pump feed.) So yeah, the coil will have drained the battery probably!
Edited by jamesfawcett on 13th Jul, 2004.
And could of although not sure, goosed the coil. I know they can overheat if left on too long.
Never mind you'll soon see, learn from your mistakes and all that! *smiley*
jamesfawcett
Member #: 218
haha
MOT is booked for 1pm!
evolotion
Member #: 83
Glasgow, Scotland
nah the leccy ignition wont enerjise the coil unless the engine is spinning :) one of the majour benefits of it
Denis O'Brien.
jamesfawcett
Member #: 218
It was fine. I was amazed, only slight choke put on, and turned the key this morning, started on first turn over! also did it for the MOT man even on a hot start! didnt even mucky the exhaust on the way down either!
did fail on a few things, the one i dont know how to do is the front top arm, i have no idea how it is assembled. I posted the certificate in the help section :) It drives lovely though! even at 4psi its quick!
