| Home > General Chat > running 2 PC together? | |||||||
29th Feb, 2008 at 06:47:14pm
Here's one for the computer buffs.
29th Feb, 2008 at 07:18:21pm
You either need a hub or a crossover cable.
29th Feb, 2008 at 07:20:41pm
Oh and whilst I think about it.. did you set static i/p addresses or is it stil DHCP? cos dhcp probably wont work without a router.. website:- http://www.terryhunt.co.uk
29th Feb, 2008 at 07:24:15pm
OMG mate this is getting hard for me, i'm not good with this i have a belkin 5e patch cable and connected the 2 pc, with no joy, could i use this cable of do i need another. Best 1/4 mile 13.2 seconds @116 mph
29th Feb, 2008 at 07:32:23pm
Unless you have fancy nics a standard network cable will not work. Also unless you set the addresses correctly it will not work.
29th Feb, 2008 at 07:36:13pm
i want to use my main one as i do now but i want to get into my "spare" one and get that working on some photos while i'm doing some other photos on the other PC, i have a switchable Key board , mouse and monitor so going between the 2 isn't an problem.
29th Feb, 2008 at 07:38:08pm
I have a spare hour, PM me you phone number and I;ll see if I can help
29th Feb, 2008 at 08:06:27pm
Thanks for your help sir, nice chatting to you, i'm not off shopping Best 1/4 mile 13.2 seconds @116 mph
3596 Posts Member #: 655 Post Whore Northern Ireland |
29th Feb, 2008 at 08:50:42pm
Buy a router....
1st Mar, 2008 at 02:46:17am
On 29th Feb, 2008 stevieturbo said:
Buy a router.... I did, and I can link 2 computers together :) Trying to link them directly, is a bloody pain in the arse. And with a router, broadband on both is easy. Yup, thats what we decided.. he's off to buy one. Plus its a firewall so you can turn the software firewall off and that makes local networks a lot easier. Edited by Turbo Tel on 1st Mar, 2008. website:- http://www.terryhunt.co.uk
1st Mar, 2008 at 07:27:02pm
Thanks Steve, Yes On Tels great advice i've just bought a belkin 4 port router, i can't connect my BB to it as i have a usb connection, but that not a worry. Now off to see if i can see my other machine :) Best 1/4 mile 13.2 seconds @116 mph
1st Mar, 2008 at 07:50:07pm
I give up, give me an engine any day!
1st Mar, 2008 at 07:56:46pm
On the computer that you want to access, go into "My Computer" right click on the drive you want to share, then select "Sharing & Security" then check "Share this folder".
1st Mar, 2008 at 08:07:28pm
Cheers, done that still no joy both. thanks any way. Best 1/4 mile 13.2 seconds @116 mph
1st Mar, 2008 at 08:52:52pm
Try running the Network Setup Wizard in Control Panel. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
1st Mar, 2008 at 09:17:01pm
Just called Matt but obviously on a Saturday night you have better things to do!
1st Mar, 2008 at 09:17:23pm
Next check that each computer has a seperate name and each are on the same workgroup, it makes things easier.
1st Mar, 2008 at 09:17:33pm
Now we finally connect..
![]() 1014 Posts Member #: 238 Post Whore essex |
1st Mar, 2008 at 09:20:06pm
hit it with a hammer! ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
1st Mar, 2008 at 09:56:07pm
Right thanks Turbo Tel , i'll give them all a go now. Best 1/4 mile 13.2 seconds @116 mph
