| Home > Help Needed / General Tech Chat > Fitting a rollcage | |||||||
77 Posts Member #: 2204 Advanced Member Hertfordshire |
1st Mar, 2008 at 04:39:07pm
Hi people
1st Mar, 2008 at 04:44:22pm
dont you need to put a ratchet strap and bend in some legs or something??
1st Mar, 2008 at 05:07:15pm
I have a safety devices one. It was a right pain in the arse to fit. It had to be compressd to get it passed the pillers. then pushed apart to bolt to the arches.
1st Mar, 2008 at 05:18:15pm
Thanks guys
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
1st Mar, 2008 at 09:13:36pm
Yep been there, complete nightmare with the rear pockets in. i had no ratchet strap and a rear diagonal but did manage to get it in, although my mates hand did suffer lol. Dependant on what you use the car for id suggest removing the rear pockets, i did this and now the cage goes in and out easy peasy. |
![]() 1014 Posts Member #: 238 Post Whore essex |
1st Mar, 2008 at 09:13:52pm
yep, use a ratchet strap to pull the legs in together, only slightly though! and i think i used a porta-power to push the legs back out a little once it was in place, and i left it in place overnight. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
2nd Mar, 2008 at 12:23:53am
i used to strong rope looped around the legs and a breaker bar to tourniquet the legs together, was a little scary when fully wound up! "Turbo's make torque, and torque makes fun"
2nd Mar, 2008 at 08:54:11am
yep rachet straps are needed, then i cut a piece of 3x2 between the legs a little longer to push them back into the right place, best of luk |
