| Home > Help Needed / General Tech Chat > removing battery box | |||||||
524 Posts Member #: 1380 Post Whore Swindon |
1st Mar, 2008 at 07:31:16pm
hi all, search only appeared to bring up a topic on a miglia exhaust and battery box but not quite what i was after in there.
neil_g, with all due respect, your the worse salesman on TM since rob_h tried to sell his own ass |
1391 Posts Member #: 1686 Post Whore Oxford |
2nd Mar, 2008 at 03:57:40pm
im pretty sure they are only spot welded in. so clean the paint off with a wire brush, get a spot weld drill bit remover and drill them all out.
OMG Robert that's a big one |
![]() 2102 Posts Member #: 432 Post Whore Swindon |
3rd Mar, 2008 at 08:13:36am
don;t be a pussy and get an angle grinder on it, will take less then 10 mins :) |
3rd Mar, 2008 at 08:03:02pm
On 3rd Mar, 2008 miniturboman said:
don;t be a pussy and get an angle grinder on it, will take less then 10 mins :) i agree with this. me-ooooow no longer a series, but still 1.3 turbo.
3rd Mar, 2008 at 08:07:58pm
I would say drill out the spotwelds (the proper way of doing it) but you probably wont be able to get a drill into some of them so grind it out
I seriously doubt it! |
3rd Mar, 2008 at 08:17:17pm
i chopped off the bottem of it, but the size of the fiberglass batery box ollie has was a concern as it is the dimentions of the original box not larger. so trying to keep as much of the original boot floor was the main bit i think, please correct me if im wrong Drives
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
3rd Mar, 2008 at 10:43:41pm
lop it out with a grinder, i did it in 1 minute, used the box as my template to make a plate to weld in the boot, welded, job done!!!!!! 1 hr total, more areodynamic & easy access to hilows both sides without taking ya rims off woo hoo SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
4th Mar, 2008 at 12:07:07pm
On 3rd Mar, 2008 clubminiflip said:
, more areodynamic & easy access to hilows both sides without taking ya rims off woo hoo Well I never thought of that. excellent idea. I need to raise the back of mine a bit. On 7th Oct, 2010 5haneJ said:
