Home > 998cc > 998 Fuel Pump
luke6040
Member #: 2144
I know this has been slighly coverd but i cant find my answer, will i still need a high pressure pump for a everyday road 998? and how the hell do i wire it up?
This seems the worest part of the project lol
Thanks
Luke
I assume that you are turboing. Yes every turbo engine will require a pump that can pump the required amount of fuel at a psi 3 or 5 above the boost pressure.
There are many different ways to wire it up. Mine is wired via a relay that is contrilled via my Megasquirt (this means it stops when the engine does. Others use the feed from the oil pressure light to feed a relay, and some just have a switch in a relay feed to cut the pump in case of an accident.
Inevery event use a relay, and preferably a fuse.
