Home > General Chat > Lobe seperation angle what is it and what does it do.
Sam
Member #: 1686
Oxford
i think its the angle between the center lines of the exhaust lobes and inlet lobes not entirely sure.
if it is that wouldn't it mean that if you narrow the LSA wouldn't it increase cylinder pressure and as a result increase the potential for detonation?
plus thinking about it bring the peak power up to a higher rpm?
sorry if its a little bit of a trivial problem, any knowledge i have is from observation when dismantling a metro block, and fairly basic physics. i haven't done a full proper rebuild yet
Thanks
Sam
OMG Robert that's a big one
Goooooogle is your friend here.
so is the yellow bible, its all outlined in there
Sam
Member #: 1686
Oxford
i had one at some point but being in a family full of mini nuts things tend to go missing.
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
larger lsa will extend rpm torque , but will lower the number
narrow it and the peak torque will be higher , but the rpm band will be narrower
about turbo, seem that 108 work very well with mid cams (basically mg na cam , 110 with longer ones ( avonbar phase 2)
Sam
Member #: 1686
Oxford
k i think i have clarifyed it abit.
thanks *happy*
