| Home > General Chat > postage prices | |||||||
![]() 157 Posts Member #: 1508 Advanced Member n ireland killyleagh |
4th Mar, 2008 at 10:17:52pm
Im after a turbo down pipe wheres the best place to get one i know there in and around £35 pound or so but the postage to N Ireland is nearly the same price as the bit im ordering!!!!
I'm stupid Ive A fiesta with most of the bits to make my megajolt thingy. Thick or what!!!! OHHHHH and ive got a metro for free !!!!! Metros have become rare over here!!!!!!!!!
5th Mar, 2008 at 08:29:01am
Rule of thumb is if it has a UK postcode, then its normal price. So you should be ok.
Edited by Jason G on 5th Mar, 2008. On 19th Jan, 2010 wil_h said:
5th Mar, 2008 at 08:35:44am
Minispares are good with postage as they use Parcelfarce. If you order online through Minisport, Avonbar and a few others it doesn't take long before the price for postage is the same as the item your buying. In this case give them a ring and queiry it, normally it's just the way the postage calculator works on internet transactions. If you call them they will normally give you a few more options i.e, Parcelfarce, Royal Snail 1st class or whatever (obviously there are size/weight restrictions). I ordered a small £25 item from Minisport and they wanted £35 postage. I rang them and they sent it Royal Snail, cost a few pounds. On 7th Nov, 2008 Nic said:
