| Home > Help Needed / General Tech Chat > Supercharger and breathers | |||||||
![]() 56 Posts Member #: 1901 Advanced Member Bolton |
5th Mar, 2008 at 11:29:47am
Hi guys,
![]() 552 Posts Member #: 300 Post Whore Cumbria |
5th Mar, 2008 at 12:52:24pm
I would say vent to atmosphere / catch tank and block the hole, you may well be getting sooted up plugs due to pulling in oil? although there's a difference between 'sooty' and 'oily'.. Here for the craic..
831 Posts Member #: 908 Post Whore gateshead |
5th Mar, 2008 at 12:56:51pm
i had this problem too and it was coming out of the bottom of the timing cover. i decided to use the crankcase breather and put that onto a t piece with one from the rocker cover and because i am running megajolt, i am using the dizzy hole as a full breather too. all this is plumbed into a catch tank and it seemed to help things balls to the blower!!!
5th Mar, 2008 at 01:02:43pm
Thanks for the replies.
194 Posts Member #: 1296 Advanced Member Milford Haven Pembrokeshire |
5th Mar, 2008 at 02:15:56pm
I've just fixed the same leak on mine following last years castle coombe trackday.
