| Home > Help Needed / General Tech Chat > Turbo Hose to Actuator | |||||||
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
13th Jul, 2004 at 09:02:42pm
I wanna get some silicon hose so I can fit my MBC my stupied actuator opens at 2PSI but I have a bleed valve so I can run a nice 7PSI for now TurboLessTosser |
13th Jul, 2004 at 09:39:51pm
IIRC 5mm will do the trick, could be 6mm though. i have all these written down somewhere! |
13th Jul, 2004 at 09:42:23pm
b12 i just used the stuff that was already on it! I blocked the other end of the T piece with a tiny bit of it. The standard hoses let the MBC stretch right up onto the bulkhead clearing all heat sources neer the wiper motor. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
14th Jul, 2004 at 02:24:04am
6mm is what you need to order... On 17th Nov, 2014 Tom Fenton said:
14th Jul, 2004 at 11:34:49am
What do you think of
TurboLessTosser |
14th Jul, 2004 at 11:44:32am
your not getting wate gate creep, your simple using a duff acatuator!!
AlexF |
14th Jul, 2004 at 01:53:45pm
if my actuator is not good , which its not , isnt a MBC just as good a chnage ?
TurboLessTosser |
14th Jul, 2004 at 03:54:39pm
Nope...
AlexF |
14th Jul, 2004 at 05:59:11pm
Steve you want my spare one? It works perfect and is still set to factory setting? PM me your address and ill post it out tomorow you will get it before avon Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
15th Jul, 2004 at 10:48:05am
feebs Ill have it mate l and of course i will send you some cash as well .... how much you want ? TurboLessTosser |
