Home > General Chat > Gearbox Caseings
Be warned this is probably one of my duller posts.
Basically I'm tring to decide which caseing to use, as well as a couple of stock boxs I've also got a Metty Turbo Box & a MPI box (I've heard the web in these is stronger but correct me if I'm wrong). Anyway I was wandering what peoples thoughts where as to which it the best casing to go for?
I would say A Plus, due to the missing extra hole on the web. But ive noticed a pattern emerging, it must have been a bad casting or somthing but on some A+ Boxes there is a split on the web but its more like a casting fault than a failure. Then ive seen others and they are perfect. Ill have to post some pics up as an example.
DAM 5626 tis best.
I thought it was a mith that the turbo box was any different to ANY A+ box apart from the bigger nosie bearing, I won't go into that now as you older members may remember a few posts last time i spoke about it lol. (not on here i would add)
So i would say Just use an A+ box, that has had the least power going through it. the only problems i've had with the boxes is them distorting, but that might just be me.
The last box i rebuilt had a small fracture in the web and the bearing popped in dead easy rather than been tapped in. The box went on an MPI mini and has had no issues upto now.
These sort of features we call "self stress releaving features" at work *happy*
neilj1678
Member #: 1297
Sunny Stockport
I could be wrong but... I've heard the later MPi casings were beefed up and they were used by Jack Knight for the 5 speed conversions. Still has DAM5626 casting number but also has JKD letters nearby too. I think they beefed up around the layshaft locating areas in the centre and end webs as these holes were enlarged by JK when fitting the special 5 speed bits
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
could you post a pic asap, as my last gearbox had exactly this syndrom of pop in too easily. I did look at it at this time but didn't found a reason to not use it, but now...
Ill have a look fab, i have numberous boxes in my collection, so ill take photos and post them up.
redwing
Member #: 1574
Malta
I have just rebuilt my gearbox and finding a decent case was my BIGGEST problem. I cleaned 3 before I found a decant one. I agree with paul you need DAM 5626 which is only found on A+ engines. You need to make sure you have the 3 bolt fixing around double roller bearing end retainer and if its a second hand box check carefully for hairline cracks. Also remember to source the diff casing as well if you are buying 2nd hand. Good luck.
redwing
Member #: 1574
Malta
PS - if you have a good MPI box I would definately use that one.
as i now have 5 engines i can have a look what caskings i have when it comes to stripping them i know one is a metro turbo one as it is a compleat engine. the others are a+ bar one which is A-series 1275GT i belive :)
Gavin Wakely
Member #: 793
Use the A+ or Turbo they as they are the same apart from the nose bearing as stated by Matt.
A+ boxes come with and without that famous bolt hole.
Vegard is right again! I have a selection of both, all A+.
hell, I never new that!
