| Home > Help Needed / General Tech Chat > K100 Head Studs | |||||||
9th Mar, 2008 at 02:13:13pm
I was planning on using the three existing head studs as recommended by the SC manual.
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
9th Mar, 2008 at 04:37:02pm
i was at the machine shop the other day and we had a similar discussion. not sure what would happen with regard to the cam pulleys lining up etc.
9th Mar, 2008 at 04:40:51pm
i wouldnt have thought that this would cause a problem with the cam pulleys because as long as they stay inline on the y axis then you should be able to move them on the x-axis enough to get the clearance you need.
9th Mar, 2008 at 04:58:02pm
My main concern was the plugging and then re-tapping of the stud holes.
9th Mar, 2008 at 07:10:21pm
ahh i see move it forwards!!! i thought you meant moving it more towards the water pump end. i dont see why it would be a problem to redrill them as that is what you have to do on a couple of the others anyway. |
9th Mar, 2008 at 07:22:38pm
How about plugging the head holes, and re-locating those?
9th Mar, 2008 at 11:05:34pm
One thing about doing it that way Dave, is the locating of the head. Id be inclined dowel the head in that case On 26th Oct, 2004 TurboDave16v said:
10th Mar, 2008 at 09:18:50am
Sprox,
10th Mar, 2008 at 09:47:52am
I did indeed, i wanted to get the head chambers dead centered over the cylinders. Optimising what i got On 26th Oct, 2004 TurboDave16v said:
10th Mar, 2008 at 10:02:29am
Did you use 3/8 BSPT plugs? and then re-drill? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
10th Mar, 2008 at 11:39:17am
10th Mar, 2008 at 02:36:08pm
looks like i will be calling the machine shop this morning!!! hopefully they havent done much more to it!! |
10th Mar, 2008 at 06:22:43pm
On 10th Mar, 2008 Paul S said:
Did you use 3/8 BSPT plugs? and then re-drill? I dont know, i left it to my machinist, he clocked up on cylinder three then marked out all the studs from a drawing i drew up on CAD. he offset milled those front three big enough for a clean fit of a plug and so that the stud would be in the middle of the plug. It was a threaded plug, but i think he made them, up probibly metric. This is the picture you were looking for Edited by Sprocket on 10th Mar, 2008. On 26th Oct, 2004 TurboDave16v said:
10th Mar, 2008 at 06:33:53pm
Thanks Sprox. Great Stuff.
Edited by Paul S on 10th Mar, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
10th Mar, 2008 at 09:18:41pm
I used 3/8 bspt plugs for my plugs, cast iron bar just to be safe on the thermal expansions. Mine overlap on the back three between plug and block, i can't see a problem with it personally and our engine builder for work said it should be okay. |
rather than clearance isues.
