Home > Wanted > Wanted - Someone to do small amount of welding.
apollo996
Member #: 1240
Worcester
Near Kidderminister/Worcester area if possible. Just need someone to weld up my pressed steel rockers on my A series race car. Very easy quick job if you can weld and have the equipment (I have neither). Case of lager in it for you! Probably take less than 1hr to do.
minidave
Member #: 889
warlingham jct6 m25 nr gatwick
can do it but am miles away
dave
cant fix it F:(k it
pm me if you want these doing
but you will have to post them to me
i never have had a problem with these
and never welded them up as per mr Vizard book..... they are a lot stronger than most peeps give them credit for *wink*
but if you want them doing ................
Edited by BENROSS on 11th Mar, 2008.
