Home > Technical Chat > KAD 6 POTS
ministef1
Member #: 1791
Cranleigh, surrey
So i went to fit my KAD 6 pots last night to see if i can use a 8.4" disc under my 10's. Which by the way, you can, i love having split rims sometimes. so much space!
But....and this is the question? I'm using mintex pads and they seem to float quite a lot up and down movement, not side to side? Is this usual?
stef
"Cars are a lifetime of pain"
ministef1
Member #: 1791
Cranleigh, surrey
why is it you hit refresh and posts everything twice......so annoying!
Don't hit refresh.
Nicky
Member #: 333
Tadley, Hampshire
Because of the way it works. Click on the topic title instead
Scruffy
Member #: 328
Seaford Rise, South Australia
stef
No mine are tight - are you using the ones from KAD based on Subaru Justy?
On 5th Sep, 2011 Vegard said:
andywaller
Member #: 1826
Maldon Essex
ah is that what they are from! i thought they were an AP pad!
I thought that too!
Hmmm justy eh?
5portsrock
Member #: 2023
nr Portsmouth ,Hampshire
depending on when you bought the 6 pots they maybe subaru justy or an AP pad shape ,they changed the caliper design slightly at some point so more pad materials were available
5portsrock
Member #: 2023
pic of the AP pad shape ,fingers crossed this works really crap with computers ,also the AP pad shape caliper has 4 metal lugs on the inner diameter held on with 4 screws to keep the pads in
5portsrock
Member #: 2023
no didnt work , i can email you the pic ,pm me
Cheers 5 port,
heres the pic of the AP pad, looks like the ones I have, which makes sense as I have some plates screwed in the caliper, i assumed they were just there to give a more durable surface though.
Scruffy
Member #: 328
That is different to the Justy pad - I see they now list two pad types!
ministef1
Member #: 1791
Cranleigh, surrey
Apparently mine were not supplied with the spring clips to keep pressure on the pads. call to KAD sorted that.
ministef1
Member #: 1791
Cranleigh, surrey
holy thread excavation, Does anyone know what the standard pads are for the 6 pot? I know the justy is mentioned, but i think there impreza? does anyone have a part number??
So can you get 8.4" under Carl's wheels?...
Mm bigger brakes
with some 8.4 setups but depends on the inner rim size, you cant get them on standard 8.4 or the 4pot version as i have tried :)
i belive most 8.4 fit under the big dish 10" though
ministef1
Member #: 1791
Cranleigh, surrey
mine did fit under the 10's, anyway 6 pot kAD pads? anyone?
Sorry stef carnt help, but yes i remember reading justy somwhere aswell. i havent my car to hand to whip a pad out to see if there is a number on but i could try see if i can find the box at work tomorrow but might end up in a lost cause .lol
Rick
ps, yes 6pots and 8.4's fit under carls 10's
pps, andywaller has 6pots aswell !!
Edited by cossierick on 18th Feb, 2013.
