| Home > Help Needed / General Tech Chat > likely condition of crank and bores from 58000 mile donar engine | |||||||
13th Mar, 2008 at 12:00:06pm
I am going to kill the metro at the weekend by pulling the engine from it. It has covered 58'000 miles. I am looking to use this engine as base for the turbo.
Edited by minimole23 on 13th Mar, 2008. On 7th Oct, 2010 5haneJ said:
13th Mar, 2008 at 01:21:19pm
Deleted, post phrased wrong so I looked like a bodger:$ Edited by minimole23 on 13th Mar, 2008. On 7th Oct, 2010 5haneJ said:
13th Mar, 2008 at 01:33:46pm
depends if you find anything nasty. not even put new bearings in my engine, there was no wear on there one i examined. mine has only done 20 odd thousand miles though. id hone and change bearings, might be worth getting new oil pump as well. then put it back together and see what you have |
13th Mar, 2008 at 03:48:16pm
Its very variable but odds are you will need a rebore, If you are buying new pistons anyway, why not?... Its the extra cost of pistons that make rebores expensive.
13th Mar, 2008 at 04:02:08pm
I already have the set of std size turbo pistons. Hmm What i will do is pull the head off and take the engine to the machineist to mic the bores up before ripping it apart fully.
13th Mar, 2008 at 04:12:13pm
There will be a noticable ridge at the top of the bore.
14th Mar, 2008 at 02:56:10pm
On 13th Mar, 2008 minimole23 said:
I already have the set of std size turbo pistons. Hmm What i will do is pull the head off and take the engine to the machineist to mic the bores up before ripping it apart fully. Sounds like you are trying to avoid the issue. The engine should be stripped and inspected if you want to be sure its OK to take the stress of a turbo. what about the camshaft? tappets? cam bearings? When you get the engine out like this wouldn't you at least want to replace the gaskets? website:- http://www.terryhunt.co.uk
14th Mar, 2008 at 03:10:08pm
No, I am going to completely rebuild the engine. New cam bearings, main bearings, big ends etc. tappets, mg metro camshaft, new piston rings. clean all the oilways out.
14th Mar, 2008 at 03:48:24pm
18th Mar, 2008 at 11:11:32am
Well, what can I say? Fookin good engine! There is a negligable wear lip - i.e virtually nothing, and where the top rings land it only has ever so slight wear flatting off the honing marks.
18th Mar, 2008 at 12:36:13pm
I am going to kill the metro at the weekend by pulling the engine from it. It has covered 58'000 miles. I am looking to use this engine as base for the turbo. Is there likely to be any appreciable bore wear, and is the crank likely to be solid still, i.e. just need a polish It really depends on how well the engine has been looked after and if it's be serviced regularly and what oil has been used in it. On 13th Mar, 2008 minimole23 said:
I already have the set of std size turbo pistons. Hmm What i will do is pull the head off and take the engine to the machineist to mic the bores up before ripping it apart fully. If you want I've got a dial bore gauge that you can borrow. What machine shop do you use? Isambard Kingdom Brunel said:
18th Mar, 2008 at 01:09:30pm
I had a engine that had done 53000 miles which had been looked after. I managed to get away with a hone of the bores and just fitted new bearings and rings, I have however just pulled it to bits for a rebore/build as it had started breathing and blue smoking. If you can afford it i would go the hole hog and fully rebore/build it otherwise just take the risk! |
18th Mar, 2008 at 03:55:17pm
I already have the set of std size turbo pistons. Hmm What i will do is pull the head off and take the engine to the machineist to mic the bores up before ripping it apart fully. If you want I've got a dial bore gauge that you can borrow. What machine shop do you use? Thanks for the offer Rob, but I am going to strip the engine I have with unmarked bores, and keep the metro engine as the reliable spare that gets thrown in during other rebuilds. I use Steve Harris for machine work, he is only 2 miles down the road. Edited by minimole23 on 18th Mar, 2008. On 7th Oct, 2010 5haneJ said:
