| Home > Help Needed / General Tech Chat > Fuelling and Lambda | |||||||
13th Mar, 2008 at 05:26:59pm
I'm really getting pissed off with my fuelling and Lambda.
13th Mar, 2008 at 05:34:44pm
I would check for air leaks first. The slighest wiff of oxygen and it will read lean - I think.
13th Mar, 2008 at 06:54:10pm
on the overrun it'll lean out. if its popping and banging through the exhaust thats one way to tell if its too lean.
13th Mar, 2008 at 07:00:48pm
Make sure the exhaust isn't blowing anywhere before the lambda, especially where the downpipe clamps to the Turbo this will affect the readings.
13th Mar, 2008 at 07:18:34pm
Lambda is on the elbow, so deffo not blowing before then.
13th Mar, 2008 at 08:06:38pm
If its a narrow band you can test it, I think you just heat with a propane torch and check the voltage coming out, about 0.8v I think--google it.. If its buggered it would show lean all the time..
13th Mar, 2008 at 08:09:21pm
Heres one..
13th Mar, 2008 at 08:15:57pm
2 whites to 12v pos and earth ,black to sensor ,if theres another wire then that goes to earth too , check all earths are really good and sound .maybe a duff sensor ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
13th Mar, 2008 at 08:35:30pm
I'm thinking a duff sensor. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
14th Mar, 2008 at 12:30:37am
plus Narrowband AFR metering is dodgy at best. 9.85 @ 145mph
14th Mar, 2008 at 07:17:49am
Yeah, I understand it's limitations, but I got it all before wideband was readily available at a decent price, jut not used it for years. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
14th Mar, 2008 at 02:28:45pm
Stick a digital multimeter on instead and see what its reading, and how it responds when driving. 9.85 @ 145mph
