Home > Help Needed / General Tech Chat > Difficult rear subframe, help needed
barkiboi
Member #: 591
Rugeley, Midlands, England
Help!!! I am just in the process of putting my mini back together after spraying and finding it nie on impossible in putting the rear subframe in. The shell was a 1994 rover mini and the subframe came from a 1970 era ish clubman estate. I thought subframes were the same? What could be causing it to be difficult, do i have to fit the later type mountings and bushes to the earlier subframe?
Many thanks
Chris
What exactly are you finding difficult?
Damn, tom beat an identical reply by 18 seconds.*smiley*
Edited by minimole23 on 13th Mar, 2008.
Do come along chop chop keep up etc....!
barkiboi
Member #: 591
the rear most mountins dont line up. they are too far back, the frame is fitted with poly bushes, dont know if i need to use a bodge bar and force it into place, is force needed?
Have you tightened the front ones up to pull the frame forwards?
barkiboi
Member #: 591
yeah pulled up tight, tried them loose aswell to see if that helps, got a lever bar to try and get some bolts in, do you think this is wise??
i think the estate subbys are diffrent
some one please correct me if iam wrong
Edited by BENROSS on 14th Mar, 2008.
You are wrong steve, they are the same.
thanks tom .....lol
evolotion
Member #: 83
Glasgow, Scotland
in my humble experience rear subbys never fit straight up, i'v only done 2 mind, but on both it took some considerable leverage to get teh frame to line up with the holes correctly.
Denis O'Brien.
turbo hogster
Member #: 178
stowmaket suffolk
just done mine with a new one and that was the same , rear wouldnt line up. but got one side in, and had to make near side rear holes a bit bigger to get bolts through, then used slightly bigger washers , when bolted up she sat true.
done loads now and they are all a pain in the arse.
The only one I've ever done that lined up right was a genuine frame into an immaculate never welded shell.
Scruffy
Member #: 328
Seaford Rise, South Australia
It will be the poly bushes not a compliant as rubber to allow for all the production tolerances! LOL Brute force ignorance requirement here. Make sure all mounts etc are loose to line everything up.
On 5th Sep, 2011 Vegard said:
we had a similar problem and simply couldn't fit the poly bushes to the rear mounts as there was not enough play in them to let the mounts line up - ended up fitting standard bushes to the inner side of the mount to give just enough play
I have poly bushes on mine and the subframe was a b!tch to fit, i used a pry bar through the mounting holes, was a very crude method!
barkiboi
Member #: 591
fitted!!!! used all of your above methods lol and no dammage to my nice new paint work, thanks for the input
