Home > Help Needed / General Tech Chat > 2 questions
Arno
Member #: 233
Beugen, Netherlands
First: Is the waste gate actuator actuated by the boost direct at the compressor or better at the plenum?
Second: if i run a dump valve do I have to block the std overpressure valve?
numero 2, block it!
numero 1, not sure.
*smiley*
Arno
Member #: 233
Beugen, Netherlands
thanks, *smiley* thats enough for now, I am at the stage of the plumbing now.
just made brackets for the throttle cable and choke, seems that my project is all about making my own parts. lot of work, hope it pays off :cool:
I & i think most others run the actuator off the compressor housing, not sure what it would be like sensing boost from the plenum ?
Phil. *smiley*
giallofly
Member #: 164
The Stig..
Newport Pagnell
Actuator is connected to the compressor and the over boost/popoff valve it the plenum is best blocked off. It will not effect your dumpvalve. Just keep your eye on your boost gauge for over boost and the ears open for nasty detonation.
Arno
Member #: 233
Beugen, Netherlands
at what pressure is the overboost/popoff valve opening?
Mirage
Member #: 119
Block off the over pressure valve.
I run my waste gate actuator from the plenum. I cant see that it would make a difference in a non intercooled ibnstallation. However you get a pressure drop over an intercooler. So if you plumb your actuator into the compressor housing, it will see more pressure than the engine. I think smaller more restrictive intercoolers would lose power, partic at high higher revs as the intercooler would be trying to flow maximum volume of air and would so be seeing maximum pressure drop over it.
