Home > General Chat > Turbo Oil Feed
In the past there has been some debate as to whether the standard oil feed (t-piece where the oil pressure switch is) is before or after the oil filter. Unfortunately I can't seem to find the old thread, so I've had to start a new one, if anyone can post a link to the oil thread (about 6 months old) it would be greatly appreciated. Anyway I took a couple of pictures which show that the oil feed is from the oil gallery & therefore after the filter.
Rob if you have the visard book, i know there is an oil passage way drawing in there which would help sort out the issue if it is or isn't filtered for you.
MadMatt
Member #: 105
Brisbane ,Australia
It is definately filtered oil comming from the oil pressure switch location.
www.miniman.com.au
rob, the oil is filterd as its from the MAIN! gallery
if you were so mind full you could place a magnetic microfine filter there so the turbo is gauranteed super filterd oil
I know, although several TM members disagreed the last time this came up, hence why I thought I'd post some pictures.
