| Home > Help Needed / General Tech Chat > edis coil pack fire order | |||||||
15th Mar, 2008 at 10:13:26pm
As above really, what is the fireing of the coil pack looking at it as if the connector was pointing to the floor and going clockwise. thanks |
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
15th Mar, 2008 at 10:52:54pm
erm the firing is the same as a mini 1342.
15th Mar, 2008 at 11:29:05pm
There is no "order" - 1 and 4 fire together as do 2 and 3.
15th Mar, 2008 at 11:30:44pm
Its a wasted spark, it fires 2 at a time.
Edited by Turbo Tel on 15th Mar, 2008. website:- http://www.terryhunt.co.uk
15th Mar, 2008 at 11:31:32pm
Is there an echo in here?? website:- http://www.terryhunt.co.uk
16th Mar, 2008 at 08:21:41am
lovely jubbly |
831 Posts Member #: 908 Post Whore gateshead |
16th Mar, 2008 at 11:25:04pm
hmmm. this might sound a bit wierd right, but i couldnt get mine to work like that. so, for a head scratching moment i put number 1 coil lead to plug number 1, number 2 to plug 2, 3 to 3 and 4 to 4. i couldnt figure out how the feck it runs, but it does! balls to the blower!!!
16th Mar, 2008 at 11:26:14pm
17th Mar, 2008 at 12:01:49am
yeah thats right stu. if you look at the coil you will see that 1 and 4 and 2 and 3 are together in pairs. |
17th Mar, 2008 at 12:02:52am
Edited by miniboo on 17th Mar, 2008. |
17th Mar, 2008 at 12:57:10am
On 17th Mar, 2008 miniboo said:
yeah thats right stu. if you look at the coil you will see that 1 and 4 and 2 and 3 are together in pairs. But sometimes people get the wiring wrong in the input plug and end up swapping the plug wires left to right to make it run. website:- http://www.terryhunt.co.uk
17th Mar, 2008 at 01:59:35am
ahh ok. when i did mine i had a full wiring harness that i just removed all the unneeded stuff. |
17th Mar, 2008 at 09:56:09am
On 17th Mar, 2008 Turbo Tel said:
But sometimes people get the wiring wrong in the input plug and end up swapping the plug wires left to right to make it run. Yes that happened to me, even though I still had the wire tails on the EDIS and coil pack to match the colours up correctly. Still must have got it wrong! On 7th Nov, 2008 Nic said:
18th Sep, 2010 at 08:05:52pm
sorry to revive this thread but to confirm,
18th Sep, 2010 at 09:06:57pm
yep that right johnny, if no 1 is on a firing stroke it will fire no 1 and no4 but cylinder 4 is on an exhaust stroke so hence the wasted spark...........unless it can be used as some form of anti lag system to keep the turbo spooling? 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
18th Sep, 2010 at 09:57:08pm
ah ok, ill try this out tomorrow |
19th Sep, 2010 at 04:51:57pm
Just a tip that Rod gave me when I was struggling with MJ. If you are testing for a spark, using one plug lead and a plug lying on the head, you wont get one !. You need to have at least two plugs from the same side of the coil pack connected. I made a little alloy plate and screwed 4 spare plugs into it and earthed that to the block so that you could see all four firing. |
