| Home > Help Needed / General Tech Chat > White Smoke/Steam.... | |||||||
150 Posts Member #: 1591 Advanced Member Prudhoe, Newcastle |
16th Mar, 2008 at 01:24:59am
Hello all.
16th Mar, 2008 at 01:32:18am
Should mention its running a refurbished carb too. I havent got a fuel pressure guage to check the reg, but it was driving fine with no problems |
16th Mar, 2008 at 01:38:44am
are you losing water at all? "Turbo's make torque, and torque makes fun"
16th Mar, 2008 at 01:42:07am
would dashpot oil have anything to do with this? |
16th Mar, 2008 at 07:00:11am
Loosing no water, gets upto temp at a normal rate, doesnt overheat
16th Mar, 2008 at 10:30:03am
If it doesn't smell, and it's white, it is most probably water.
In the 13's at last!.. Just |
16th Mar, 2008 at 10:35:00am
i would leave it a bit, its quite humid at the minute and hot/cold all the time. if you're not using it much it could well just be water in the exhaust. its amazing how long that can last! |
16th Mar, 2008 at 10:57:37am
yip if its a fresh build then jsut ignore it, most likely jsut water in the exhaust, drive it and see how it develops :) turbo 16v k-series 11.9@118.9 :)
16th Mar, 2008 at 06:59:20pm
Would water leaking into a piston cause a tapping sort of noise? The smoke is there from turning the key, but seems to clear when the engine gets above the halfway mark, the white line on the std 3clock temp gauge.
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
16th Mar, 2008 at 07:25:05pm
an airlock may have caused excessive heat in one spot
16th Mar, 2008 at 07:36:02pm
My thoughts also.
17th Mar, 2008 at 12:01:15am
take out the plugs, turn it over and see if any water comes out |
17th Mar, 2008 at 12:45:19am
That sounds perfectly normal for this time of year. Have at look at the other cars on the road first thing in a morning, and all the recently started cars will have smoking exhausts.
On 16th Mar, 2008 JordieNE said:
The smoke is there from turning the key, but seems to clear when the engine gets above the halfway mark, the white line on the std 3clock temp gauge. |
17th Mar, 2008 at 06:34:28am
Its constant smoke, increasing with revs, for about 20-30mins then it clears abit. Leave car 10mins to cool, and start it up again and its the same.
17th Mar, 2008 at 07:14:02am
Engine warm, no choke, idling abit fast here cos i had been messing with the mixture/idle speed eariler.
17th Mar, 2008 at 09:13:32am
re check tAPPETS ,and check oil level in sump , try to lower it to low point on dipstick and try again . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
17th Mar, 2008 at 09:37:37am
defo the tappets On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
17th Mar, 2008 at 11:43:08pm
Had to get the head skimmed 12thou to get it straight. So new gasket, carb gaskets etc, fresh oil and filter and its running champion now.
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
18th Mar, 2008 at 12:06:57am
is it all sorted now? the vid kinda looked bluish smoke but not overly blue, just my opinion tho David. |
18th Mar, 2008 at 12:09:52am
Yeah, running clear as a daisy now. Gas tester reading 3.00% which i think is a pass. Engine seems to idle ok, temp is fine, no water loss. |
18th Mar, 2008 at 08:51:14am
Good work!
